EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Mercedes-Benz engines with 48-volt systems coming in 2017 (https://ecomodder.com/forum/showthread.php/mercedes-benz-engines-48-volt-systems-coming-2017-a-33955.html)
Daox 06-16-2016 12:15 PM
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1466093604
Well, someone is finally doing it. There has been talk of this for ages now. Its good to see someone stepping out.
Mercedes-Benz engines with 48-volt systems coming in 2017 - Autoblog
Mercedes will use the 48-volt systems to power mild-hybrid functions like energy recuperation (commonly called brake regeneration), engine stop-start, electric boost, and even moving a car from a stop on electric power alone. These features will be enabled through either an integrated starter-generator (Mercedes abbreviates it ISG) or a belt-driven generator (RSG).
The industry is moving toward 48-volt power, with the SAE working on a standard for the systems and Delphi claiming a 10-percent increase in fuel economy for cars that make the switch.
MetroMPG 06-16-2016 04:49 PM
I heard about that lethal 50v threshold a few times when we were building the ForkenSwift.
Which makes me wonder: as a 48v nominal system, the running voltage will probably be higher than 50. Is it still "safe" in terms of the 50v threshold?
Also: I find it funny that they're marketing this as a voltage upgrade rather than as a "mild" hybrid, because it adds the same features that mild hybridization does.
Ecky 06-16-2016 08:44 PM
Will these still have a 12v battery and use a DC-DC converter, or will all of the interior components run on 48v?
oil pan 4 06-16-2016 10:51 PM
Charging voltage on a "48 volt system" will have to be at least 56 volts.
Daox 06-17-2016 10:12 AM
I would imagine they would use a 48V battery with components running at 48V. If thats the way the industry is moving you might as well go for it.
MetroMPG 06-17-2016 10:23 AM
I thought the article implied there would still be a small 12v battery.
EDIT: yup
Cars can retain a cheaper 12-volt battery for lower-power accessories and run the high-draw systems on the 48-volt circuit.
Not sure if that's a generic statement or if it applies to the Merc approach.
Ecky 06-17-2016 02:30 PM
I'm inclined to think they'll go with a single lithium pack though, with a bit more capacity than 4x 12v lead acids would have, for mild-hybrid functions.
