Old 11-28-2007, 08:20 AM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Expanding, sprayable foam as an aero construction / shaping material
Had a thought recently after reading about the shaped foam board construction of an aerodynamic prototype which was used to make a mold. ... Ever since I made the Kardboard Kammback, I've been thinking about foam/fiberglass construction approaches.
I went up to the Home Depot and picked up an $8 pressurized can of high expansion urethane foam this evening.
"Cured foam dries rigid and can be shaped, sanded, trimmed, painted or stained."
Hmmm...
I'm going to try this stuff out making a couple of things on the car:
- shaped deflectors ahead of all 4 wheels/tires
- radiused transition at the aft edge of the front wheel arches (I've got lots of space between the arch and the tire to do this)
- possibly also boat-tailing behind the front wheels/tires
- this might make a good grill block plug material - custom fit! - though I've already got a "bra" on that does that job.
Tin foil taped/pressed in the area that will serve as the base of the object being created makes a decent non-reactive "release agent", and will protect the paint.
It'll be a bit of an experiment to see how well it adheres to vertical & upside-down surfaces, and whether I need to approach it in layers, or do it all at once.
Then of course the big issue will be discovering how nice or not it is to shape/smooth & what techniques work best.
Old 01-10-2008, 09:22 PM   #2 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Expanding foam is a neat-o material.
It is also IMPOSSIBLE to remove from my favorite t-shirt.
Be carefully using it. Wear disposable clothing...
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-10-2008, 09:24 PM   #3 (permalink)
Oh, I've got lots of disposable clothing since I started messing around with flooded lead acid batteries. (Formerly good clothing, I don't have to add. :P)
Old 01-10-2008, 09:25 PM   #4 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
It comes off your hands if you use emery paper.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 01-10-2008, 09:41 PM   #5 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
use cardboard and masking tape to reinforce it if you make a large part. Just make some narrow 1/2" strips of cardboard or paper internally to help it hold it's shape better. Once you get it formed you can sand it carefully then cover it with a layer of lightweight fiberglass body filler then paint it.
I have patched body panels on cars like that and it actually works really well. You can use a high speed sanding wheel to shape the foam a bit lower than you want it then cover it with fiberglass body filler. Smooth the filler like any other body panel then you can paint it and it is perfect looking.
Also it is nearly impossible to keep the nozzle clear after you use it so once you start using it, make all the parts you want. It will probably be clogged up next time you go to use the can
Old 01-10-2008, 10:31 PM   #6 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
You'll know you got most of it off when the bleeding starts.
Why does such an otherwise wonderful product have to be such a P.I.T.A.?
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-11-2008, 11:44 AM   #7 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Acetone cuts through it before it cures.
Great idea! I'll have to look into that.
Old 01-11-2008, 12:04 PM   #8 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
I've used "great stuff" for making foam parts and such.... Not sure what type of foam it is off hand - but you can't make too thick a layer otherwise the innards won't cure...
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 01-11-2008, 12:07 PM   #9 (permalink)
you can make thicker layers.. .just have to poke holes so the air can get to the inners... i've embedded straws from McDonalds in mine till it cured... then just trim the straw ends off
Old 01-12-2008, 12:13 AM   #10 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Lightbulb whoa i got this stuff lyin around
KEWL
I bought some of this recently and was using it to fill empty spaces in the Geo. It takes several cans to fill the spare tire hole. I wanted to keep the back as flat as possible, so's I can still use it to haul engines and stuff from the boneyard to home.
I still be the neighborhood fixer-upper doncha know.
BTW. A Metro 1.0 will actually haul (in one load) :
2 300+# men
1 400+# 5.0 V8 fully dressed
1 250 # 727 Torque Flight Transmission
1 ??? # front grill for early full size Bronco
But you don't get home as fast as you went. S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
