Old 04-10-2011, 01:43 PM   #1 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Lightbulb Torque converter lockup control relay setup...
This is the relay setup I came up with after looking at the starter kill relay setup over at this page at the12volt.com.
My thread over at ToyotaNation.com...
Old 04-10-2011, 03:45 PM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Here's how the DPDT (double pole, double throw) switch will be configured...
The yellow wire from the relays will return back to the solenoid leg of the switch.
Old 04-19-2013, 02:25 PM   #3 (permalink)
EcoPlotting
night9's Avatar
Sliver - '12 Hyundai Elantra limited
90 day: 35.1 mpg (US)
t-ruck - '06 chevy Colorado Lt
90 day: 21.88 mpg (US)
Bob - '09 Harley Sportster Nightster
90 day: 38.88 mpg (US)
Pearl - '14 Toyota Prius C 3
90 day: 48.1 mpg (US)
Did you ever get this to work for you?
Old 04-22-2013, 11:39 PM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I never hooked it up but it will work just fine as the diagram shows fer my transmission. You'll need to substitute the proper resistor fer yer vehicle's TC lock relay.
I was thinking about hooking up the brake disconnect switch to the first solenoid ground wire. This will de-energize the solenoid when the ground is disconnected.
I've been looking to build a plug and play adapter to connect in between the wiring harness and the transmission socket. This would allow me to test it without cutting into the wiring harness.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 05-31-2013, 03:23 PM   #5 (permalink)
Can you explain what you mean by using a resister per car? This looks interesting to me as I have an automatic.
Old 05-31-2013, 06:40 PM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Knowing what the resistance value of yer TC solenoid is will determine what the proper resistance value you need to substitute in the diagram. Fer my transmission...the value is ~13ohms so I would use a 13ohm resistor. I'm pretty sure that all TC solenoids are not the same value.
