MetroMPG.com mailbag: what about lightweight rims?
1 Attachment(s)
Got another one this week:
They're particularly good for city driving - or any situation where speed is changing frequently (pulse & glide, anyone?). All the "high performance" cars - at both ends of the performance spectrum - have 'em. Ferarris to Civic VX's. Honda Canada just added the rims from its hybrid model as standard equipment on its non-hybrid 5-speed model (along with LRR tires, underbody panels and a deck lid spoiler) to lower the fuel consumption enough to earn an efficiency rebate from the government. (And now the non-hybrid looks identical to the hybrid). Weight reduction in general is a favourite ecomodding tactic, but pound for pound, it's even more effective to take off rotating mass than static mass. I've read in various places that taking off 1 lb of rotating mass is the same as removing anywhere from 7 to 16 lbs elsewhere (there's the Internet for ya). [EDIT: this bit of fuzzy Internet fluff is corrected below.] The problem for me is my car has an uncommon bolt pattern. Whatever the Honda pattern is, it's not the Geo's! Ask me how I know. When I was shopping for my first Firefly, I had a set of VX rims sitting in the garage waiting. Unfortunately, the closest I got to putting them on the car was in Photoshop.... http://forum.ecomodder.com/attachmen...1&d=1197596519 If the Metros had an affordable, lightweight 13 inch rim option like the Honda people have, it would be on the Blackfly in a heartbeat. And a heartbeat later, they'd disappear behind a smooth wheel cover. :) . |
I even took the VX rims in to my machinist friend (the guy who made the motor/tranny coupler for the ForkenSwift) to see if he would drill out a new set of holes in the VX rims that would fit the Firefly's stud pattern (that's why on the rear wheel in the above pic, you can see I Photoshopped the 8-hole pattern, to see what it'd look like).
But he said, nuh-uh. Honda (or the rim supplier) optimized these rims so much for weight that they scooped out material on the back side in between the original stud holes. So buddy said: "If I were in my 20's and this was for MY OWN car, I might try it. But I'm older and wiser now, and I've seen stuff break. I just don't think there's enough meat in the hub area of these rims to machine out your new holes without compromising them." |
Got another reply from the (shy) asker of the original question:
But going to a 12 inch rim would mean using a smaller diameter tire as well. And that would effectively reduce my gearing (making the engine spin faster at a given road speed). I expect that would reduce my fuel economy more than any savings I'd gain from the lighter rim/tire combo. Also, my car has quite good low rolling resistance tires. If I could find a set of lighter rims that would fit, I'd want to keep using these tires. |
Thank you for questioning this. It forced me to do a bit more digging for a credible source on the subject --- and put this bit of fluff to rest: "taking off 1 lb of rotating mass is the same as removing anywhere from 7 to 16 lbs elsewhere"
First - agreed on the handling benefits of unsprung weight. On the issue of rotating mass... Quote:
Here's a credible source giving an overview of the 1:2 relationship, in response to this question: Quote:
It's not always 1:2, it depends on the distributions of the rotational mass. :)
That's true. Both sources mention that. But it's more than 1:1!
Based on what the almighty wikiality says, the second quote is incorrect since the distribution of weight on a car wheel isn't nearly as pronounced as on a bicycle, aka the ideal case of a mass at some distance from the center. Car wheels tend to be pretty beefy IME, and weigh more than or about the same as a tire, and since the disk or drum is rotating too, there's even more mass close to the center. This implies the moment of inertia is likely significantly less than .5mr^2 IMO. Offhand I would guess that a tire wheel combo has maybe ~25% more KE than a static body moving at the same speed.
This does bring up an interesting point though. If you've looked at tire specs, you may have noticed that wider tires weigh significantly more than their skinnier counterparts. Since all this weight is near the edge, I would guess that the choice of tire can influence acceleration/deceleration as much as or more than lighter wheels could. That being said, the only fuel efficiency property that depends on mass in an ideal situation, Rolling resistance=mg(Crr), depends on mass alone AFAIK. While larger wheels/tires may hurt acceleration, braking, and handling, I don't see how they do anything to influence the energy needed to move a vehicle down the road. |
I haven't looked at tire specs, but what you say seems reasonable.
It also makes sense that wheel/tire mass makes little difference at constant speed. But I'd still get the lighter wheels if I could. The majority of my fuel savings comes from the P&G technique = repeatedly accelerating (and at a fairly brisk rate). In those circumstances, or for driving that's primarily urban, it makes sense to reduce wheel/tire mass. For highway cruising or DWL, not so much. About the question of RR being solely a mass issue, I wonder how much aerodynamic lift a typical car generates at highway speeds... :) (Just kidding.) |
I don't think it makes any difference at any speed unless the driver can't account for the increase in KE via having larger coasting distances. I mean, less mass is good for normal city traffic in that marginally less energy is lost when everyone gets on the brakes from some speed. But if we stay off the brakes, having more KE at some given speed isn't an issue at all since it'll just take us slightly farther as we coast down. IMO, lighter wheels just aren't worth the cash to those looking to get better mileage compared to just about anything else.
Your point about it being a fractional gain is valid.
But I'm in it for fractional gains too. At some point, the low hanging fruit has been picked. And unfortunately, not every pulse ends in a glide. So, if I can save 30 lbs by removing the passenger seat, vs. 30 lbs by swapping wheels (I think that's what Ben saved going to VX rims from his stock steelies), I'd still do it. (Actually, I'd probably do both.) |
But at what cost would you still do both? ;)
That's easy: at an affordable cost!
I knew you would say something like that...
http://i.slickdeals.net/images/smilies2/whee.gif |
uh... this really doesn't have to do with lightweight rims, but it does have to do with rims. Would packing the rims with snow so they resemble pizza cutters improve mileage or diminish it? My rims if you look at them are pretty smooth, but if I packed them to be solid white circles would that help? it's nice and snowy here and using the weather to my advantage instead of my enemy is my favorite thing.
Recently I read an article in Hot VW's in which a fuel mileage oriented air-cooled VW engine was being built. They intentionally used heavy rotating and reciprocating internal parts in the engine, including a heavy flywheel. I think their point was that the engine would store and hold on longer to the energy invested in it to get it up to speed. It seems like this idea plays into your "pulse and glide" tactic. Heavy wheels and tires should also act as flywheels, causing you to be able to glide further, shouldn't it? While it may take more energy to get up to speed, it will keep that speed longer(?) If this is so, maybe it would be better to save weight elsewhere on the car, and go heavier on wheels/tires.
As a weekend autocrosser (G-Stock Neon ACR) I am very aware that lighter wheels/tires are much better for performance and handling, just as a light flywheel and light pistons/rods etc. makes for a more responsive and quicker revving engine. But are they best for fuel economy for those using techniques such as those hypermilers use? I don't know, but I just bought a '96 Geo Metro 3 cyl 5-speed for my daily driver and want to try my hand at this fuel mileage game. I'd like to know what you think. I know, I know; autocross seems like such a waste of gas! But my Neon probably gets better mileage on the course than most of the other cars out there; it's only about 45 seconds per run; it makes you a better driver, and it's FUN!!! |
I wouldn't pack any wheels with snow. Density of your pack picking pursuit is bound to be different at certain places. Bounce and erratic wheel behavior will ensue. Perhaps life stopping death. Now, we don't want that happening to you.
I think it would be a reasonably easy thing to test if you have access to the stuff needed.
Find a tire shop that they know you at and borrow all their wheel weights and stick the entire lot on your car's rims :) Then you can test and see how much that changes things. It should be easy to add a few pounds to each wheel so on a small car with small tires it should be measurable if it actually does anything. You could also measure the changes in how it does pulse and glide, if it glides farther for just a tiny bit longer pulse or if the longer pulse is equal to the longer glide. Just keep track of where the old wheel weights go so when you take them off you don't take the originals off. |
These 13 inch rims are just 11 pounds and should work for your metro! geometroforum.com/topic/4271097/1/
