Minimum grill opening requirement
2 Attachment(s)
I worked up a spreadsheet that (supposedly) calculates a grill opening requirement. ...I couldn't find this calculation elsewhere so I'm assuming this is helpful...
EDIT 1/6/13: I added a term for the loss of heat through the exhaust gas. This matters because the exhaust gas is much much hotter than the radiator, so although it is a smaller volume it represents about 20% of the total thermal load. Therefore my new area calcs are about 20% lower than previously. My purpose is to help guide grill block design (since I'm doing one soon). I.e. how far does your grill need to open and under what conditions can you expect it to be required? I think it's particularly crude since I don't know how much the radiator actually heats the air that passes through it, but I'm making an assumption so I can use the specific heat of air to determine heat dissipation for a given flow rate. Most likely the openings I calculate are low for that reason, but they are probably not so terribly off to be a bad reference point. It'd probably be good if someone can check my work. I checked my drag force against the one on the wiki, and most of what else I did seems straight forward, but who knows? :rolleyes: Assuming it's all correct, here is some tabulation of typical results: EDIT 1/6/13 I corrected the values to include heat lost through the exhaust gas. I also thought that 22% for ICE thermodynamic efficiency is low and used 28% instead, an important rationale is that cooling requirements are most stringent while climbing, but in that condition throttle loss will be low and thermodynamic efficiency will be higher than normal. For the 0% grades I backed off to 25%, which may be reasonable for economy cars but not sportier cars. The net result of both changes is almost a 50% reduction in my grille area suggestions below:
(I think this spreadsheet is also less accurate when you're not climbing, because it assumes that the air through the grill is the only means of cooling, which is more true when the cooling demand is very high (lots of horsepower in use), and it's particularly untrue at low ambient temperature and of course the whole premise is false if your trip is short.) (Note that where I write in^2/hp I'm referring to wheel output hp. I get the feeling that I must be typically climbing at least 2X below my Civic's "specified" engine power output for some reason, maybe because I don't like the sound of high RPMs and like to keep it in 5th mostly, and use 4th for pulses when I drop below 60MPH.) Conclusions (not surprising):
BTW, this is my first time posting here, but I have really enjoyed this site since I found it earlier this year. I've been hypermiling since 2007 and I really wish I'd found this site earlier. I'm now nearly finished with phase I of my aero mods on my Civic (wheel slicks and passenger mirror delete). Phase II will be front end and wheel skirts. For phase III I'm thinking I will make a partial-boattail-type shell for my hitch-mounted luggage rack that my family of 4 uses on long hauls. (Sooner or later I'll put my stuff in the ecomodder garage too.) |
It all depends on the drag through the cooling system. If it is fully ducted and has an efficient intake opening and well placed exhaust vent (see Hucho on this) then the sizing I remember reading about (maybe in reference to NASCAR?) is 16in^2 per 100HP.
Hi Neil,
I disagree with the idea of using racing rules in application to passenger cars.
I'm also not convinced that the drag through the cooling system affects the cooling system efficiency... as opposed to Cd. |
I'm doing a grill block for Baa at the moment, working out opening size by trial and error. The first afternoon, coolant temp started climbing (fast) on the motorway at 110kph. I stopped and took off the whole grill block. Last night, with a much larger opening, temp was fine on the motorway and only started to rise (slowly) on the climb through the Blue Mountains at 80kph. With the opening a little larger again, I'm hoping for no increase in temp on the way home tonight.:) |
The drag of the cooling system contributes up to about 10% of the overall drag of the vehicle. This is one of the advantages of an electric drivetrain, by the way.
I'm cooling my ~105HP Scion xA with a ~15" x 4" opening. And that is with minimal changes to the overall system. With an efficient exhaust vent, this could be reduced a lot more. Vekke has a car cooled with just a 4" diameter intake. You should look at the Hucho section on cooling system drag. And several folks here on EM have added exhaust vents in the center of the hood that greatly improves cooling by increasing flow through by lowering drag inside the system. |
I like your
approach to predict engine coolant temp with your listed factors. Might add humidity level, in-town/stop and go traffic, electric fan vs. full time mechanical fan vs. temp. activated mech. fan. "Hot" ambient temps equals my a/c on (around 15 hp loss) and activation of the temp. triggered mechanical fan(around 15 hp loss). I have to turn off air just to get away from a stop light. Total hp for the 2.5 L Mazda engine is 107 hp no acc.'s. Both fan and A/C 107-30hp='s 77hp for a 3400 lb(me and daily gear). Ouch.
Solution for me: full block radiator block and transmission heaters.Variable air intake block. I have a 2.5 foot "Super Bird" nose that is fully sealed to both the radiator and A/C "radiator" so that any admitted air is ducted directly to the radiators. I'm using an ABS cover plate that I move manually to admit none, some, or more air. Goal: Regulate incoming air in summer temp's to keep mech. fan off and be able to use A/C in a pulse and glide manner. This includes stop and go and highway speeds. Trial and error for the factors had allowed me to "figure" the opening needed. Don't have to change this much. Only takes 2-3 minutes to change the opening( four screws, loosen and move ). Working well. As Leon Russell sang..." Up on the tightwire...on side is ice and the others fire..." Future: Manual control from the driver's seat. |
The only air intake in my Canyon is an opening under and behind the license plate. It's been enough, even in the summer with the AC running.
Running into issues with this, on my car the section under the bumper has a factory airdam, that significantly contributes to the cooling system. In order to run a full undertray, that has to be removed, but removing it significantly increases cooling system temps at speed. In the summer, I can block 90% of the front grill area, as long as that factory airdam behind and under the bumper is still on. But with half of the factory grill blocked, and the airdam removed, the car overheats during the hottest summer months. I'll get pics in an hour or so to illustrate the area. |
sticky
The mod-data sticky should have Walter Korff's low-drag cooling inlet diagram.You'll want to see it as it is germane to your project.
Now I understand the advantage of the ducted, low drag cooling design. Are there any DIY build threads / pages on that approach? I want to think in terms of cost-benefit, it's easier to assess difficulty if it's been done already - bonus points if the benefits are A-B-A tested or CFD'd. This seems like a frontier of ecomodding.
But my calcs may still be useful, as a guideline it probably applies somewhat to both ducted and non-ducted designs. A good ducted design would have the advantage that the Cd is less affected by the opening, so variable blocking would be less of a concern. |
Stop-and-go traffic is too complicated for me. At low speeds your fan may turn on to compensate for low air flow. Other than that, if you're staying off the brakes and getting good gas mileage, grill opening demand should be no more than a little higher than at cruising. |
My grill block experience with '96 Geo Metro 3cyl 5spd: For what it's worth, I made a roadside, ad hoc grill blocker over a year ago on my '96 Metro. I used cardboard to fashion my behind the grill ducting, made such that the little air that gets through, MUST go threw the tiny radiator. I completely covered the factory openings in the bumper, thick plastic from a 5qt Castrol oil jug, held on with Gorrilla tape. The only air the radiator gets is from the slit that exists between the bumper cover and the lower lip of the hood, about 10" wide x 1-1/2" tall.
I monitor coolant temp and incoming air temp via my scan gauge. I've never had the coolant temp go up, but IAT is slightly higher, maybe 15degF. The only noticeable difference on this vehicle, blocked versus unblocked, is the electric fan comes on more often in summer, at lower speeds, idling, and in stop and go traffic. The fan never triggers to come on while driving over 35mph, and it always keeps up with the additional heat, even with restricted air flow. I did not do back to back testing, but I think the ducting is helping mange what little air does get in. |
I'm going to try some ducting experiments this weekend, and post back on here. I'm also going to close off that bottom area where the airdam is supposed to be and see if it gets hot with a duct to the radiator. |
The one mod I made was to block up the escape vent holes in the chin area, after I had blocked up most of the grill. Because the stock grill opening was way too big, they had to let air escape; but after the grill blocks are in, all the air needs to go through the radiator. So, in my case it is not so much a duct, but rather a plenum.
An exhaust louver in the center of the hood would greatly improved the flow, but that is a lot of work. |
I was looking at this, including drawing C in the page that Aerohead mentioned, but after tuft testing the hood, there isnt an area that doesnt show attached flow with the upper grill block in place. So there isnt a way to suck that air on on my car without putting some sort of lip in front the vent, which seems it would be detrimental to overall aero. At this point it seems the rear radiator idea is still the best option for me, depending on this weekends tests.
...have you seen Ford's Patent for their "air-deflecting" grill, maybe it can provide some useful info(?): http://www.google.com/patents?id=zyM...ed=0CDQQ6AEwAA
grille-deja vu
Aerohead, to be honest, I don't know the answer to your question (FoC'78), only that the current Ford grills, with their multiple, broad, wide, slats are *supposed* to be 'dynamically' aerodynamic with increased speed, ie: air flow 'thru' the grill is reduced as the speed is increased...similar to *how* hydrodynamic water flow becomes 'blocked' through wire-mesh at higher speeds but not at lower speeds.
similar
My air dam spans from the upper part of the bumper to about 4" above the ground. Only air inlet is Twenty four 3/4" holes in the air dam right in front of the bumper inlet. The drivers side is completely blocked inside the bumper and the AC condenser and the gap between the two is completely blocked. So all the air that goes through those holes goes right into the radiator.
The grill block is held on by only 2 zip ties so if the gauge does start to climb I cut them off and add the upper grill to the air flow. |
vena contracta
...what aerohead was alluding to (from Wiki):
It is the ratio between the area of the jet at the vena contracta to the area of the orifice. Cc = area at vena contracta/ area of orifice The typical value may be taken as 0.64 for a sharp orifice (concentric with the flow channel). The smaller the value, the more effect the vena contracta has. |
Adjustments: inclusion of heat lost to exhaust, fiddling with ICE efficiency
I was thinking about my calculation a few weeks ago and it occurred to me that heat is lost to the exhaust as well as the radiator. Air passing through the radiator is (probably) only heated to 180-200F or so, but the exhaust is at about 1000F when it exits the engine compartment, so it's significant. I worked the exhaust heat out to about 22% of the ICE thermal load, and I updated my spreadsheet to reflect that. I edited my first post with the new attachment.
Also, I'm pretty sure the number I used for ICE thermodynamic efficiency, 22%, is lower than I'd expect under climbing conditions. I think 28% is more likely, at least for economy cars, considering low throttle losses during climbing. Net result; most of my suggested grille openings have gone down by almost 50%. I edited my original table accordingly. Quote:
I am now working on a design to shroud the outlet side of the radiator and use this shroud to control airflow through radiator, so if the radiator outlet is controlled, how relevant is the blocking of the actual grill because the flow is already restricted by the shroud? Edit: Just to add I have a top mounted intercooler with bonnet scoop, which also performs better with all excess holes sealed and this is where the engine bay area gets the bulk of it's ventilation from in a downdraft fashion, I have a very narrow gap on the exhaust side which allows a small amount of air past the intercooler and down past the exhaust to keep this area at a reasonable temp. |
40 sq in. and 150 bhp
At Bonneville I blocked the trash can lid opening down to 40 square inches for the last couple of runs.The 150 bhp engine was capable of 124 bhp at the track and at WOT for a mile the temp gauge never really moved.
I left the block in place and drove on to Carson City, Nevada and then back home here to the Dallas/Ft.Worth area and never had a cooling problem. On one 10,600 pass in Colorado I did run the heater to full heat and max blower setting to augment the cooling system. The block is still in place today and I've had no trouble in daily commuting or 70 mph travel. |
I have measured my lupo 3l with 1.2 tdi engine fully blocked grill:
When outside temperature is +5 celsius it works up to 105 km/h. after that speed fan kicks in and you can drive up 125 km/h and after that speeds the water temperature starts to be over 100 celsius and rises. If outside temperature goes to -10 celsius or colder you can drive +15 km/h faster without the fan kicking in and +25 km/h faster to reach over 100 celsius. |
thermal efficiency
As you add drag reduction your heat flux is going to go down and down as your road load falls lower and lower.And of course your cooling requirements will fall as a consequence as your numbers-crunching is showing. As long as you can 'open' your grille for worst-case scenario driving loads,or impart a higher static pressure across the heat exchanger (electric fans) you ought to be able to address the full spectrum of loads. The fixed,concentric bullet valve behind my inlet, is intended as a 'future' active element to optimize cooling air flow (complete shutoff during winter parking,etc.) but since it is not within the KISS design framework must languish until that system is idiot-proofed. |
