EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   minneapolis- where to get coroplast sheets (https://ecomodder.com/forum/showthread.php/minneapolis-where-get-coroplast-sheets-15926.html)
laack 01-27-2011 11:47 AM
I've been waiting until it warmed up to do an aerocap for the ranger, but my patience has run out. Where can i buy large sheets of coroplast or lexan/anything else that is easy to shape and still cheap. Ive been calling around a bunch of random sign shops, but none will sell me a sheet over 24x36". Can anyone in the area refer me to a shop that you have used, or an online vendor that keepstotal price + shipping cost reasonable.
BamZipPow 01-27-2011 01:35 PM
Corrugated Plastic Signs, Coroplast Full Color Signs Printed on 4 mm coroplast, 10mm coroplast, 6mm coroplast, Discount Signs.
I just called them and they said a single raw stock 4mm 4'x8' sheet in white would run you $24 plus tax. Talked to Maureen...give her a call. :D
Have you tried the yer local city recycling center fer any leftover coroplast signs from the election? ;)
Something else you might want to try (if coroplast is so hard to git up there) is go to yer local appliance store and see if they will give you some large cardboard boxes that you can use the cardboard from. I know it's not waterproof...but it will git you some material to work with. Once you create some workable patterns...hopefully you will have some coroplast to work with. ;)
TomO 01-27-2011 03:39 PM
ABC Sign Shop is where I got mine from, in person, for $20 per sheet.
KITT222 01-27-2011 05:56 PM
Thanks! These will help when I run out...
