EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   misc signal sources. (https://ecomodder.com/forum/showthread.php/misc-signal-sources-7545.html)
dcb 03-20-2009 05:02 PM
http://img124.exs.cx/img124/2267/DLC1.jpg
I'm not even sure what vehicle this is exactly, maybe some kind of hyundai, but they put a vehicle speed signal on the obd port pin 14? Maybe this is your car if you have connections on 1,4,7,8,12,14,15,16?
gyb 07-14-2009 11:17 AM
My car is a Hyundai Accent 2000 1.5L (Imported from Singapore) and it has Vehicle Speed in pin 14 of OBD2 connector.
4 - Chassis ground
5 - Signal ground
7 - K line
12 - Airbag
14 - VSS
16 - Battery voltage
It uses ISO9141-2.
