Mitsubishi engine swap: Ford Model T gets plug-in hybrid drivetrain
2 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=14952074051917 Mitsubishi Model A
Are hybridized antiques becoming a thing? Mitsubishi is marking 100 years of auto production by recreating its first car, with a twist. There aren't any 1917 Mitsu Model A's around anymore, so they're using a Model T as the basis for the reconstruction, into which they're sticking the plug-in drivetrain from the Outlander hybrid. The project is being done in California, and will be televised: Quote:
Jalopnik is covering it too: http://ecomodder.com/forum/attachmen...1&d=1495207732 Quote:
Sounds like a fun project.
my inner purist is screaming.
But a cool idea :D |
It's not even a Front-engined, RWD setup...
Does anyone make a hybrid drivetrain that is? |
Yeah, I'm wondering whether they're going to just drop the T body on the modified Outlander chassis, or actually move the running gear into the T.
The donor SUV is AWD, by the way. I think Toyota has a couple of RWD front engine hybrids. Their flagship Lexus sedan is, and I think there's a Lexus RWD hybrid coupe. BMW & Merc also do PHEV RWD hybrids. |
Coupling the hybrid driveline with a T-model pedal-operated "3-speeder":D
I've never driven a T, but it would be an interesting experience, from videos I've seen.
https://upload.wikimedia.org/wikiped...away_front.jpg
https://en.wikipedia.org/wiki/File:Mitsubishi_Outlander_PHEV_cutaway_front.jpg Here's the nut West Coast Customs need to crack. A boxy package that fits between the Mapherson strut towers. No worse than an Ardun heads on a Ford V-8. I suggest replacing the Macpherson struts with rocker arms. |
The Outlander PHEV is a sibling to the i-MiEV, and the i-MiEV RWD drivetrain would almost certainly fit beneath that Mitsu Model A rear body all in one compact package. Of course, the PHEV has more panache and profit, so perhaps that's why they're taking the more challenging route.
You needed all 3 ratios to make it up certain hills you had to drive up in reverse because both forward gears were too high and reverse was "low" |
https://simple.wikipedia.org/wiki/Ford_Model_T: Quote:
the 3-speeder is good if you have the additional "Muncie" Box, giving you 7 speeds :D one of them gears is having both gearboxes in reverse so you can creep up hills
oh, the T had and still has a lot of aftermarket :D
One of the reasons for backing up a steep hill in a Model T was fuel supply. They did not have a fuel pump and the tank was under the seat. By backing up a steep hill you still had fuel getting to the updraft carb. My best friend's dad had one when we were in high school, we drove it around every summer.
http://cdn.automovelbrasil.com/800/2...0c251df1ba.jpg |
