MK2 Golf Brake Master Cylinder Question.
Some of you may know that my master cylinder needs to be replaced... I'm looking for a non-power master cylinder, so I can get rid of the brake booster and vacuum pump, reducing weight and parasitic losses.
Ideally, it should be a bolt in unit, but if anyone knows what cars I should be looking at, or even has one laying about for sale or free, it would be appreciated. |
I think you have to find like a 1964 model to not have power brakes :)
Just get some more leverage/travel. Raise the pedal pivot up and lengthen the arm (or pound the floor lower and lengthen the arm). My golf never really had power brakes, no sweat. edit: I suppose you could also change where the plunger connects with the pedal slightly, for more leverage, and maybe increase the pedal travel by grinding on something. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
