Modding the MPGuino
Came up with an idea the other day for adding lights to the MPGuino.
Previously posted in the MPGuino release one workspace: I was thinking about adding code for a 'Red / Green' indicator (2 LEDs hooked up to the outputs) Red would come on if instant was lower than Current, Green would come on if instant was higher than tank. Check to see if backlight was not 0 before turning the light on. Code:
// in header section I feel that this would give an instant, eyes up, indication of your driving efficiency based upon bettering your averages. By basing it on both tank and current you will have 4 different states possible:
While I cant tell you if this is correct or not. I would like to have a single LED on mine to light up when Instant MPG > Tank MPG. Did you ever try this to see if it works out? If it does, maybe I can just wire up a green led to pin 10 and use only the code for instant>tank. Great Idea!
ERIK |
I have since started driving a new car. So I have not gone ahead with it. Also, not having any feedback on the idea for a month left me without much interest.
After my emergency house re-model, I will look into doing it. |
I have a secondary idea that I thought would be neat. I find myself watching my gallons per hour a lot during accelerations, with my goal of being under .7 or .8 gph. I was thinking the same idea only with gallons per hour would also be very useful, since I have noticed that accelerating more slowly is helping take the edge off the cooler weather. It's a great idea, I haven't tried anything with it yet either, but thought it would be easy enough if I wasn't able to get the hang of the sound my car makes around .8 gph.
I would really like to know if this code would work okay to light up the led's. Can anyone verify this is written properly?
Another idea: can we use on of the other analog inputs to monitor a CHT sensor on the plugs? That would be great for other mods (O2 leaning)
Hey guys! Nice mod!!!
Did anyone tested it yet? I would like to impliment it to my mpguino but i can not compile it with the canadian version 0.82 it's just drives me crazy :mad: but nice idea i'll keep trying, if anyone manages to do it please share it with us! :thumbup: here it seams to be the problem : instantmpg()>tank.mpg instantmpg()>current.mpg They have different names on the canadian version but i can not find them |
if(instantdistanceperfuelunit()>tank.distanceperfu elunit()){
if(instantdistanceperfuelunit()>current.distancepe rfuelunit()){ It does compile it , but is it ok?:confused: |
