Models that don't work on real cars
Aerohead has a belief, that has unfortunately been apparently adopted by many people here, which is quite wrong.
That belief is that The Template (and roughly similar shapes) have zero lift. Of course, these shapes have in fact very high lift. Aerohead often quotes references to support this incorrect belief, but the clearest and most accessible he has quoted is Figure 2.4, page 51 of Hucho (second edition). So let's look at that diagram. (Note that I not going to (mis)quote or paraphrase, as Aerohead does so often. Instead, I will reproduce the diagrams and text.) The diagram Aerohead references: https://i.postimg.cc/zG9CGvRy/Fig-2-4.jpg Now, what does Aerohead say about it? He said: Quote:
And does that matter? Let's look at what is written on the next page: https://i.postimg.cc/QMvhPLwG/second-page.jpg Note from the passage: On the rear part of the vehicle's upper surface a steep pressure rise occurs, and it is in this region where considerable differences exist between the real flow of a viscous fluid and the inviscid flow shown here. and If all X-components of the pressure distribution on the vehicle surface are integrated, the result for the drag will be D=0. and In the real, viscous flow there exists a drag force, but it cannot be explained by considering an ideal, inviscid fluid. None of this is much of a surprise to me - if you measure real stuff on real cars on real roads, you quickly find where people have misunderstood (or mis-applied) theory. The idea that Aerohead constantly pushes that low drag = low lift is simply rubbish. It's one of many misconceptions he has, most of which are very easily shown by getting away from the keyboard and doing some real-world measurements on the road. It's not hard - and it might prevent silly mistakes like referencing a diagram for inviscid fluid as if it applies to real cars. |
When I drove a "new beetle" which is about as close as you can get to the template on a street driven car, that thing generated lift and had horrible cD.
It had to use a spoiler so the back wheels would stay planted to the road surface. But quoting 2 generations out of date stuff is kind of his thing. |
Beetles slop down way too fast to conform to the template anyway, not exactly an apples to apples comparison.
The simplest way to look at it:
Rounded surface creates lower pressure. Look at an air foil, the top surface creates lift by lowering the pressure. Overall shape of the car is rounded, thus creates lower pressure on that surface (varying levels). Low pressure on the top half of the car is lift. Flip a car upside down and you get down force right? :D |
It's been done.
https://ecomodder.com/forum/member-f...wu5wo1-500.jpg Quote:
To follow The Template, max camber needs to be at 30% of the length. Thanks OP, I hadn't seen this one before: https://i.postimg.cc/zG9CGvRy/Fig-2-4.jpg What do you make of the internal dotted lines? They seem to imply that pressure differentials transmit through a solid body. ??? I'm patiently waiting for the inexorable: duckduckgo.com/?q=CFD Open+VDB and Blender. The best link appears to be: Quote:
https://www.fetchcfd.com/view-project/192 This will bring it down from supercomputer level to the hobbyist. You don't even need to have a garage full of 2nd hand game consoles Beowolfed into a render farm. |
The key point is that the pressures shown on this diagram do not apply to real cars. |
Got it. According to Simulation Theory it's all varying degrees of verisimilitude.
1 Attachment(s)
https://www.sciencedirect.com/topics...rodynamic-lift Quote:
Although I've long been fascinated with automobile aerodynamics, I don't have enough knowledge and interest to speak of the science, so I usually don't bother parroting what's accepted as common knowledge here.
I know there's been prior debate of the subject of the template I haven't read, so if this information has been discussed to death feel free to disregard this post; but I feel like information, pictures, and videos on this page would be relevant to the discussion. |
Thanks. Bubblemania is an interesting site. They cover things like Luigi Colani and Ed Roth and domes.
The page you linked is more than just the Schlorwagen, which is iconic; then Persu et al. I've stood next to the Lewis Airomobile in a museum. I remember the Riley heads in old Ford roadsters, but I'd never seen what must be the Ur-Lakester: http://bubblemania.fr/wp-content/uploads/CI-600x426.jpg http://bubblemania.fr/wp-content/uploads/CI-600x426.jpg In case you haven't seen it, I'll repost my motor home design. https://ecomodder.com/forum/member-f...07-7-35-02.png I keep reposting it in case it turns up in a Google Bing DuckDuckGo search for Elon Musk so he sees it. Not touching Twitter. |
Note: I am not saying that these cars are of no interest, or they they were backward at the time. In fact I am a great fan of them. But.... The Cd values recorded at the time for these cars are highly unreliable, as has been demonstrated when full-size cars of the past have been tested in modern wind tunnels. ...and... The designers of the time cared nothing about lift, and so basically all the shapes shown are of such high lift they would never be released by any responsible car company today. ...and... In general, the designers were not aware of the drag resulting from trailing vortices, and so attached flow was often seen as an end in itself. More than anything else, these factors explain why no current cars look anything like these cars. For exactly the same reasons, it also explains why using some sort of standardised approach (a template) based on these ideas is usually a pretty bad idea, and using such a template as some sort of model for changing an existing car is an even worse idea. |
So it is generally better to not use any kind of template then?
Makes sense given the big differences that exist between different vehicles. |
Then we have lot of tools at our disposal to measure nearly every aspect of car aero on the road at low or zero cost. Here's a few:
That way, you find out what works for your specific car in terms of exactly what you want to achieve. For car aero, guesswork and blindly following what others have done on different cars in the past is exactly the same as for any other area of car modification. And what's that? It's likely to result in much poorer results than could have been achieved through some simple test and development. |
I'm not worried about lift much, at least not at reasonable speed. If anything it slightly lowers rolling resistance, but I don't expect much of that. It will also slightly reduce grip of course, but again not by much.
If lift is the price to pay for less drag I'll take it with both hands. |
I am biased - I spend 90 per cent of my driving on country (rural) roads at 100 and 110 km/h (~60 - 70 mph) and the change in lift is obvious on my car (I have measurable downforce at those speeds). I also overtake at considerably higher speeds (often on narrow and poor roads). And of course, any headwind simply adds to the airspeed. But that's completely your decision - if you're happy with lift (and maybe lots of lift) and lower drag, then that's a decision you can take. It's an interesting area. Despite driving a lot of cars, I didn't realise the significance of lift until I changed it on my Insight. Then I realised the 'it feels better, the faster you go' that I'd associated more with good suspension damping is probably in large part due to a lack of aero lift. |
Overtaking? What is that? :p
I'm happy if a slowpoke ahead gives me an excuse to slow down, and though I keep a respectable distance sometimes the wake can be noticed in extra reduced fuel consumption. Then I have other reasons. I have tinnitus (whistling ears) and it gets worse with more external sound. And I like my car, am in no hurry to arrive at my destination to flee it. I never have the feeling that I suffer from excess lift. I do have instability in side wind though, which I think may be related to the rounded corners of the rear bumpers (where a Prius and many other cars now have a sharp fold) but it about vanishes with a mildly raised tire pressure at the back, especially when on 16" rims (versus the 15" narrow steels for my winter tires). It is an useful indicator now to the point where any instability makes me check tire pressure at the next stop, with a couple of hits (slow leak due to a screw in the tire!) |
I like the idea of using cardboard to test modifications. Obviously it is much cheaper than bolting/welding sheet metal to the body. |
Thanks! |
Most of my modifications improved crosswind performance and increased down-force. I also got an mpg bump, which is nice. However if mpg were my only goal then an S10 or Tacoma would not be my base vehicle. UPLIFT has long been an underated issue in this forum in my opinion. This is a good thread. |
New Beetle
2) The original Beetle was tested by ROAD & TRACK in 1969. It had no rear lift whatsoever. 3) Too bad you didn't drive the XL1. It IS a 'template' car. |
diagram
The car has quite a rear overhang, and with a positive pressure acting over a 23 % body-length moment arm, going beyond the rear axle it generates significant downforce. Diffusers can also provide a counterbalance with respect to overall lift. -------------------------------------------------------------------------------------- As to low drag / low lift, don't get obsessive about the upper body pressure profile without investigating under the vehicle. Spirit generated 22-pounds rear lift at 135-mph. And 30-pounds downforce on the front axle. Her travel weight was over 4,200 - pounds. My travel speed was 65-mph. Any lift at that velocity wouldn't be on the radar screen at all. Just take the squares of each velocity and compare them as a percentage. |
this page
lift
better not to
Time isn't money. We can just p... away our lives repeating experiments done millions of times before. Forget the plumbing code and standardized fittings. Structural engineering? Who needs it. Skip the rebar, those 'tables' are rubbish. Medical school. I'll do that C-section for a fraction of the cost. Wing sections. Logs will do with enough horsepower.There's your real bragging rights! Just take all the accumulated knowledge of the last 4,000-years and throw it out the window. We can better spend our time reinventing everything. |
The LFRD method for calculating steel members was replaced with another method a few years after I got out of college.
In other words, this is an example where a standard of science was improved upon and replaced. Many such examples outside of architecture and structural engineering exist. In my reading today on this topic I picked up that standard aerodynamic theory and calculations and even CFD can and will be improved upon as the quest for lower drag aircraft continues. In short, science marches on. I can see both discarding the past and building on the past as needed. We in this forum are not in pursuit of that last 2-percent of perfection, so rules of thumbs and templates have a role in my opinion. I do wish there was a template or more illuminative guide for UPLIFT though. The extra 50 lbs of down-force I seat of the pants guessed my S10 pickup truck roof wing gives allows me to not use 4WD in heavy rain and still take wide bending curves on Pontiac Trail at 50 mph at night. This means I save gas and get to my destination on time. 50 lbs may not seem like a lot, but it is enough to make a difference in my comfort zone. |
I'm carrying 50lb of downforce I could stand to lose. :)
An off-topic example: elemental.medium.com: A Supercomputer Analyzed Covid-19 — and an Interesting New Theory Has Emerged A closer look at the Bradykinin hypothesis |
I also can't remember where I came across the information, but I'm positive that car was highly unstable at highish speeds, as well as being quite huge. |
:facepalm: I've violated the long established axiom of opening my mouth and removing doubt of my foolishness.
OTOH, someone looked at the link you provided.
