Old 05-16-2025, 12:08 PM   #21 (permalink)
Y2kbug
y2kbug's Avatar
1999 corolla - '99 Toyota Corolla CE
90 day: 39.57 mpg (US)
03 dakota v6 2wd auto - '03 Dodge Dakota
Team Dodge
90 day: 19.18 mpg (US)
Break it again and use the drifter stitch:
https://youtu.be/RqVuQMB1_2s
I actually had zipties holding it together for the past 2 years. my dad used to use zipties on his ae86 and 240 when he drifted. He said he would rather the zipties break and verses the bumper rip and get completely destroyed
The Following 2 Users Say Thank You to y2kbug For This Useful Post:
aerohead (05-19-2025), freebeard (05-16-2025)
Old 05-16-2025, 12:46 PM   #22 (permalink)
AE86? I guess I'm preaching to the choir.
"...a heart can be broken, but a circle goes on forever" -- Bill Keane
Old 05-16-2025, 07:46 PM   #23 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
I went with a belly pan instead of an air dam. (I have broken/ripped loose air dams in normal driving in 2 other cars). The Coroplast has held up to winter driving for 15 years. Seal up around the rear fenders and perhaps add a drain hole at the low point. Be sure to really seal the front edge, so it doesn't get ripped off by the wind and you may need to make more allowances for the exhaust on your car. My car is a diesel and has much cooler exhaust than a gasoline engine vehicle.
https://ecomodder.com/forum/member-c...-img-0146.html
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 2 Users Say Thank You to COcyclist For This Useful Post:
aerohead (05-19-2025), kach22i (05-17-2025)
