EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Modifying displayed digits/decimals (https://ecomodder.com/forum/showthread.php/modifying-displayed-digits-decimals-25865.html)
rickjames8 05-14-2013 11:57 PM
Hello,
I've been using my MPGuino for a couple of weeks now and love it. However, I'm wondering if I can change the number of digits displayed by hacking the code slightly.
For instance, my preferred display is Instant/Current, which reads like this
IM075.45 SP055.43
CM048.34 DI156.65
It takes a second to focus on the info I want. What I'd rather see is:
IM 075.4 SP 55.4
CM 48.3 DI 156
The IM fluctuates so fast, theres no need for 1/100ths accuracy. I don't see myself going over 99mph in the Civic, so 2 digits there is fine. I guess what I'm saying is that I'd sacrifice some accuracy, and remove some leading zeros to have a cleaner screen if it was possible to modify the code. I didn't see a mention of it on the wiki.
-Rick
nickdigger 05-18-2013 12:36 AM
I posted an improved format() procedure in:
Code hacks - EcoModder
It prints leading spaces instead of zeroes, and you can change the number of digits and decimal places. For example, "format(instantmph(),2,0)" would print "75". Or, "format(instantmph(),5,2)" would print " 75.33".
I think it was written for an earlier version of the code (0.82), but it might work in the current code without too much tweaking. If nothing else, it's a starting point to fix the ugly default.
