Moon Wheel Covers
I just got a 2017 Kia Niro FE and not a fan of the stock wheel covers and was wondering if the "moon" wheel covers would help areo. I'm assuming so, and leads to main reason for the post... Anyone know a good place to get moon wheel covers? 16" wheels on my car and have found several online, including eBay for $80 shipped for a set, but I'm guessing you all will be more help than I've found via Google (which isn't much).
Thanks in advance!! |
I'm pretty sure they do. I was thinking about doing the same thing to my Elantra. Might not be a really noticeable difference, but worth a shot. ;)
On my old Astro van I got 5 mpg from steel wheels, LRR tires, and clip on moon style hub caps. Also its worth noting that I ran those tires @ 50 psi. (15 over the sidewall)
http://ecomodder.com/forum/fe-graphs/graph9493.gif |
I had genuine Moon's on my Kangoo for ~20000km. Not a hint of them coming loose and in fact they were always really hard to get off.
A few people report loosing discs at very low milages. My guess is they bought the cheap knock offs. |
Be advised, moon discs probably won't fit your alloy wheels. You'll end up having to do something like this.
https://www.mooneyesusa.com/v/vspfil...MD11-DZ-2T.jpg https://www.mooneyesusa.com/MOON-Dis...-p/md11-dz.htm |
I had these on my Astro.
http://static.speedwaymotors.com/RS/...91139614_L.jpg Full Moon Style 15 Inch Wheel Covers, Set/4 |
I documented the steps I took to put moon discs on my Insight Ron Burgundy here:
http://ecomodder.com/forum/showthrea...tml#post485077 |
So I've contacted a few companies and so far all have said theirs won't clip over my stock wheels. I won't damage the wheels to put them on (drilling/etc). I'm now wondering if I could pull off the pizza pan mod that I didn't know was an option. Just trying to think of how I could do it as I don't want to damage the stock hubcaps either, maybe get a second set and tweak them?
I've finally started seeing these on Class 8 trucks here in the USA. That crowd has always been ahead of the curve with aero since the oil price spike after Hurricane Katrina.
in the truck world, even a small improvement per 1000 miles is noticeable money.
Especially, if you own the truck you drive :) |
MOON aero
*a tri-spoke wheel had Cd 0.038 *a flat disc wheel had Cd 0.364 *a convex full disc was Cd 0.361 |
