Mopar to offer Diesel Swap kit for Wranglers
Was avoiding homework and came across this. Would be pretty sweet if it does come into production.
http://blogs.4wdandsportutility.com/...kit/index.html Quote:
:P The only hang up I could see getting the VM 2.8 into a ZJ would be the Body computer if you guys have one. Else a 4.0 is a 4.0
I have to chime-in as a very-infrequent off-roader (and Jeep fan) -- but this has to be perfect to supply the the torque in 4-low applications. My only question/concern: does it have a turbo? That could be a flaw: turbo lag and all...
RH77 |
i want one for my jk though :P guess ill just have to settle with puting one in my tj
Few more bits of info. It will be turbo charged, but actually makes less power. (125/225) vs (190/240) of the 4.0. Along with a max cruising range of 372 miles and a 19 gallon tank, that calculates an avg MPG of around 19.5. Not that great for a diesel.
http://www.aav.com.eg/diesel_data.html · Max crusing range On road.............................km............... .600+ (372mi) Off road............................km................ 460 – 500+ Terrain dependent · Fuel tank capacity............liter ...........…. 72 (19 gallon tank, stock) 5 – Engine · Type …................................................. ............................................Diesel · Make …................................................. ......................................VM Motori · Model …................................................. ....................................2.8L Diesel · Aspiration .................................................. ......................... Turbo-Charged · No. of cylinders …................................................. ................................... 4 · Bore x stroke (mm) .................................................. .................... 94 x 100 · Displacement (cm3) …..................................171 in³ ......................2800 cm³ · Compression ratio .................................................. ................. 17.5 ± 0.5:1 · Max power (hp @ rpm) …. 120 hp @ 3800 rpm...................90 kw @ 3800 rpm · Max torque (Nm @ rpm) …. 225 lb-ft @ 2000 rpm.............305 Nm @ 2000 rpm · Operating range (rpm) …................................................. ..... Idle - 3800 rpm · Indicated mean effective pressure (psi) .................................................. 196 · Type of cylinder liner .................................................. ......................... Iron · Engine oil capacity …................................................. ........................ 5.1 kg · Turbo charge .................................................. ................................... Yes Type.............................................. .....................Pneumatic Wastegate Valve 1-Make.............................................. .................................................. ...IHI 2-Model............................................. .............................................. RHF 4H 3-Number of stages............................................ ................................. Single 4-Max pressure of each stage (bar) ..............................................1,1± 50mbar 5-Inter-cooler .................................................. ...............................Air to Air |
I herd they were having a lot of problems with the 2.8L diesel.
Bad enough to were people were using the "lemon law" to return and break leases on 2.8L diesels that kept breaking down. But I believe most problems were turbo and electrical related. So the simpler version of the 2.8 might work great. The 6.5L chevy diesel swap is fairly popular to jeepers also. |
I wouldn't want that computerized wonder in my Jeep. I really doubt you could tune it for more MPG. I think these later diesels are too complex to last for the long haul.
Now if we were looking at a cummins 4BT 3.9L I'd be saving my pennys for one. |
A friend has a Liberty diesel. He sent the ECU off to a place called Green Diesel and is loving it.
