A more "conventional" solar car going around the world (2 passenger, 2 door)
(Hopefully this isn't a re-post...)
http://www.hochschule-bochum.de/typo...391783e29a.jpg (Currently in the southern USA...) A german student engineering team is driving a solar powered car around the world. Details on their site: SolarCar - SolarCar - Hochschule Bochum It's a somewhat more "conventional" car than the no-holds-barred flat as an aerodynamic pancake solar racers we're used to seeing. (Of course, only an EcoModder would call it "conventional" looking. :) ) Quote:
http://www.youtube.com/watch?v=iNZZlnSEukw |
The vehicle specs:
SolarWorld GT - SolarCar - Hochschule Bochum Vehicle Dimension Length 4090 mm Width 1600 mm Height approx. 1335 mm Vehicle Weight Total Weight 260 kg Aerodynamics Front surface 1,71 mē Coefficient of drag 0.137 cw Motor Controlpanel Manufacturer Tritium Max Power 100 A Weight 4 kg Solar Generator Manufacturer Azur Space Cell type Gallium Arsenid Performance ~ 1,1 W Cell efficiency ~ 29,2% Records Top Speed approx. 120 km/h More specs: SolarWorld GT - SolarCar - Hochschule Bochum |
There are two posts on that car . I thought you might have seen them.
That car is truly amazing. Plenty of hip and headroom, a realistic ride height, two conventional doors, and a somewhat more ' normal ' shape. Point fourteen drag coefficient. ( actually just under .14 ) POINT FOURTEEN ! |
http://ecomodder.com/forum/showthrea...tml#post284714
Page 26 or so. ( Thanks Neil ! ) The other post actually has " Solar World GT " in the title, but I'm having trouble finding it at the moment - using my phone to post this. |
http://ecomodder.com/forum/showthrea...-gt-20385.html
It's got two hub motors in the front wheels. The range on the battery (I think they have a larger battery pack in it for the world tour?) is supposed to be 240 miles; though we don't know what speed. It apparently can drive all day if the sun is shining. Awesome car, and I think Phil (aerohead) and someone else on the forum will be trying to get to see it on one of the stops in the USA. |
Darren,
One of the joys of owning the forum is the ability to delete previous posts so you can say "I was first". Just sayin.;) Kirk |
I'm not above admitting defeat!
I was away while most of that thread was going on, so locking this one (it's all duplication!). Go to: http://ecomodder.com/forum/showthrea...4-a-20385.html |
