04-23-2020, 01:29 AM
Cyborg ECU
More data on smooth wheel covers effectiveness
A couple key findings on smooth wheel covers of interest to this forum, from:
Sofie Koitrand, Adrian Gaylard, and Gianluca Orso Fiet, "An Investigation of Wheel Aerodynamic Effects for a Saloon Car" - Conference Paper - September 2015
Conference: Progress in Vehicle Aerodynamics and Thermal Management: Proceedings of the 10th FKFS-Conference, At Stuttgart, Germany
The PDF is currently available online for free. Thanks to the authors and their professional org for that. I will share just a small portion of their findings, but there is more. Go get their paper and read it if you want more.
In another thread, a few forum members have been discussing the effectiveness of several aeromods for wheels. This study uses a wind tunnel (with 5 belts) and CFD to study these different wheel designs:
The conclusion was that the fully blanked, smooth cover wheel saw the greatest reduction in drag:
That graph presents a combination of the wind tunnel & CFD data. In the wind tunnel alone, the fully blanked wheel saw a delta of -0.013 Cd, the 85mm annular blanked wheel -0.009, and the 430mm center-blanked ("Tesla" style) wheel saw a -0.003 Cd delta.
Their conclusion is that in this test fully smooth covered or blanked wheels produced the greatest Cd benefit over baseline, whether measured in a wind tunnel or using CFD. This is a different conclusion than some other recent studies.
The Following 6 Users Say Thank You to California98Civic For This Useful Post:
04-23-2020, 02:28 AM
Good find. Note that the graph you have shown simply displays the difference in CFD prediction vs wind tunnel results (ie the error) - not the actual changes in drag.
Versus the standard rim (wind tunnel results):
- fully blanked - Cd change of -0.013
- 85mm annular outer ring - Cd change of -0.009
So the Jaguar results are different to the Tesla results (where fully covered wheels increased drag), which in turn are different to the SAE 2011-01-0165 results (where ventilated front and fully covered rear wheels gave the best result).
As I wrote in the other thread:
To make it clear, based on the research I have cited in the book, I am not saying that fully covered wheels are bad. What I am saying is that fully-covered wheels aren't always best.
I am guessing it's highly dependent on the car to which the wheels are fitted.
The Following 3 Users Say Thank You to JulianEdgar For This Useful Post:
04-23-2020, 02:46 AM
Cyborg ECU
- 85mm annular outer ring - Cd change of -0.012
I already noted these data points in the OP. But you get the number wrong here. The wind tunnel results for the 85mm ring were -0.009. You are mistakenly quoting the CFD number of -0.012. It's on p.248, table 18.3.
04-23-2020, 02:57 AM
On a car, at 65mph that could be up to a 1hp reduction in power requirement to maintain speed.
Not bad.
04-23-2020, 03:01 AM
Cyborg ECU
Not bad.
Right?! Their testing speed was 140 kph, I think. But still. I'd like to think my wheel covers gimme back an HP at 65 mph cruising.
04-23-2020, 03:07 AM
At autobahn speed you are definitely saving at least 1hp.
04-23-2020, 03:41 AM
You are right! I have edited my post.
04-24-2020, 01:56 AM
Of course, absent from this discussion is the need for brake cooling, which from a manufacturer's perspective is probably at least as important as aerodynamic efficiency. (And I think it is pretty important too!)
04-24-2020, 03:22 AM
#9 (permalink)
Citation needed?
www.researchgate.net: An Investigation of Wheel Aerodynamic Effects
for a Saloon Car
I remember the name Adrian Gaylard from discussions a few years back.
Originally Posted by DDG
Adrian Gaylard - Technical Specialist - Computational ...
https://www.linkedin.com/in/apgaylard
Progress in Vehicle Aerodynamics and Thermal Management, 9th FKFS-Conference October 1, 2013 Realistic turbulent flow conditions, typical for highway driving, can have a significant effect on ...
LinkedIn wants an email address. No thanks. U of Georgia and Coventry University were also notable. A lot of the materials disappeared, I had captured a few Powerpoint slides like this (added to my album in 2013(!)):
I did a search and surfaced a few other interesting articles at ReasearchGate:
www.researchgate.net/publication: Automotive Aerodynamics Special Issue Surface contamination of cars: a review
https://www.researchgate.net: The importance of unsteady aerodynamics to road vehicle dynamics
There are links to other articles at the bottom of some of those. Examples:
Optimization of the aerodynamic drag reduction of a passenger hatchback car
July 2018 · Proceedings of the Institution of Mechanical Engineers Part G Journal of Aerospace Engineering
Proposal of an Aerodynamic Concept for Automotive Drag Reduction
November 2014
Drag Reduction Devices
Adrian Gaylard Martin Passmore Max Varney[...]Y.A. Irving Brown
I [think I] remember this one:
www.researchgate.net: The Effect of Base Bleed and Rear Cavities on the Drag of an SUV
I wonder whether they really went away and are back, or what?
04-24-2020, 03:30 AM
#10 (permalink)
Yes, Adrian is a lovely guy.
He gave extraordinarily detailed feedback on each of the book chapters I sent him.
Through him, I also got the Jaguar XE for a week to aero test, and then I was able to compare the on-the-road test results with his 'official' Jaguar CFD - and have him comment on the differences!
Really down-to-earth and quite frank in his feedback.
