The most 'normal' solar car i've seen.
Other than the skinny tires, and potato chip thinness of the car, the Sunswift eVe is the most normal solar car I have seen to date.
Even the roof height of the car is not as low as the usual solar car. The shape is quite nice as well - even if it were powered by an ICE. Wow :thumbup: Weight is just 700 lbs ( yes seven hundred ) and the Cd is point 16. http://insideevs.com/wp-content/uplo...record_run.jpg http://images.gizmag.com/hero/sunswift-eve-offical.jpg http://www.solarracing.org/wp-conten...Sunswift_4.jpg Sunswift Students Build an Electric Car With Better Range Than a Tesla | WIRED https://www.youtube.com/watch?v=1bUd-5wqncI#t=31 Here the car attempts to break the FIA speed record over a 500km course ( thats over 60 mph over 310 miles - just amazing : https://www.youtube.com/watch?v=ihwmtRQngcc I came across the car on this thread at the excellent site landspeedracing.com:Oldsmobile Aerotech? It's an actual 'doorslammer' too ( looks manta ray like in this image to me ) :http://www.wired.com/wp-content/uplo...ne-660x350.jpg |
EDIT : The thread title should have read " The most normal solar car I've seen ( Sunswift eVe ) "
Also, i just realized this should be in the Fossil Fuel Free section. Here is that 'dynamic' image above straightened out : http://i877.photobucket.com/albums/a...record_run.jpg |
From the Wired article:
"The drive was made over 120 laps on the 2.6-mile “Highway Circuit” at the Australian Automotive Research Centre in Victoria. A pair of drivers drove in three stints, swapping when the teams did tire changes to avoid fatigue." I wonder what kind of tires were they using if they needed to be replaced two times on a 310 mile run. |
Love the looks of the car. I'd drive it in a heart beat.
http://www.jamestownliquor.com/jstli...es/fosters.jpg |
If the tires have to be changed that often at anything less than F1 cornering speeds and downforce it makes you wonder if those special tires just happen to have an engine, fuel tank and rolling thread aboard... :)
I think durability has been sacrificed for light weight and Xtremely low rolling resistance.
bit more info: Michelin - Solar Tyres | World Solar Challenge 2015 |
tire wear
I suspect that the continuous curves of a track environment scrubbed off the rubber at an accelerated rate, Alex Tremulis said he was losing 20-mpg at 55-mph in the Subaru XT-100 when in the curves of his test track. |
Here is a quote from that site i linked to earlier from a guy going by the name Graham :
UNSW Australia's solar-electric car Sunswift eVe added a "tail" like this for their successful FIA record attempt for fastest electric vehicle over 500km. The car was not designed to set records, but rather as a semi-practical road car primarily built for the 2013 World Solar Challenge rally across Australia. My student Simon Ambrose did the CFD work to design the tail, the original car had a "chopped" back to fit lights and a registration plate and the air had a bit of a downwash component to it leaving the body. Simon's design added about 0.4m to the car but largely eliminated the downwash and reduced the overall drag of the vehicle by about 5%. I've attached a couple of pictures. You can see that in some ways it was a pretty crude addition but it definitely did the job. We ran a dual-level tunnel under the whole car, otherwise yes indeed we'd have had a whopping amount of downforce - great for a racing car, terrible for a solar car. " And here is a link to the thread again :Oldsmobile Aerotech? They brought up a good question concerning the bottom curvature on the Olds Aerotech tail. The long tailed version had a angle much greater than what is supposed to be ideal. It's a really great aero forum there, and worth a look. |
