Motor 90V DC PM 19 amp like new
Motor 90V DC PM 19 amp treadmill like new
I have a Like new Treadmill motor I was planning to use in a light motorcycle or scooter, but now i have my rolling chassis (Honda CRF230) and This may be a bit too small for a full size bike. The motor was sent as a warranty replacement but ended up not being needed, so it has no wear on it. It is from a higher end treadmill, not a cheap department store brand. I used to sell these treadmills and they had zero motor problems and pulled very strong - so i believe the quality is very good. in fact, the distributor put a lifetime warranty on the motor in these treadmills, now that shows confidence! (no warranty on this one, had to be in treadmill of course). Specs on the motor: (Permanent Magnet DC Brushed) 90 Volts Rotation CW 2.4 HP (this would be a conservative peak rating most likely, like a 10 min rating, likely could handle a bit more for burst acceleration). 4000 rpm 19 amp The Mfr. "Joong Chenn" is not a motor company, although some of the treadmill manufacturers to build their own motors. Would work well on a scooter or small dirt bike (pit bike or 80cc size or similar). It has a cooling fan attached on one end, and a flywheel with ribbed pulley for belt drive (can be removed of course). Can send without flywheel to save shipping cost if you don't want it. Will consider TRADE for useful motorcycle ev parts as i am just starting to decide what components to use. Looking for $150 plus shipping. I'm in Canada, shipping would be around $30 to most north American locations. If interested pm or email me dballstar at gmail dot com |
