Motorbike generates 200W of power from its own exhaust fumes
Hello -
Motorbike generates 200W of power from its own exhaust fumes | Science! | Geek.com Quote:
Motorbike Generates Electricity Using Its Exhaust Gas -- Tech-On! Quote:
Would it be light enough?
200 Watt is not a lot. A 9 kg 1kWh LiFePO4 battery pack can provide 2,000 W for half an hour, like my commute. I'd need to charge it of course, but it would have much more of an impact than this. And would it be cheap enough? The thermoelectric conversion elements I've seen were all expensive, ineffective and heavy. What you'd gain you'd lose on having to haul the extra weight, never mind earning anything back. If they'd work on cars they certainly would work in fixed applications that run 24/7. So, where are they? For just 200W it needs to be very light and quite cheap. If so, why not. I have yet to find the first system that does effectively harvest thermal heat from exhaust systems that is of any use for cars. Green turbine states it: Quote:
The answer I got was (iirc) that it was still experimental and not ready to fit to a car at all. It would not take the exhaust gas directly; that should be used to heat a medium gas to drive the turbine and be cooled by an extra radiator. Thanks for your interest, keep reading the news letter... They may be on to something, but I doubt it would ever be practical for a car. 20% total FC reduction from just exhaust gas heat seems very unlikely to me. |
There are also memory-wire motors that can be used to power a low-speed alternator to provide electrical power from the exhaust waste heat. Much cheaper than thermoelectrics.
It would need to provide at least 50 Watt per kilo (25 Watt per pound) or its mass alone would hurt acceleration even at full output, assuming a typical 1000 kilogram econobox with an 50 kW engine.
Can you show a memory wire motor that can provide more than 25 Watt for every pound of its own weight? |
It could displace the alternator. The alternator isn't much but taking any load off the engine = good, especially if it can be picked up by harvesting energy from waste heat.
I think what everyone is waiting for is suitable high temperature thermoelectric modules that are cheaper. Because of the requirement for an onboard generator to be light and the fact that electrical energy isn't as useful in a gasoline powered car, the main problem is cost. I think Alphabet Energy or something has newer TEGs that are maybe viable but I don't think you can buy them.
It shouldn't be hard to remove most of the alternator's load, you can generate 300W with commercially available units for about 1500 dollars and something like 10lbs weight which isn't too bad, but the cost has to be trimmed down a lot if it's ever going to pay for itself. |
The problem is not so much the weight of the unit itself.
To make the cooling part effective it needs to be big, and probably heavy. Unless we could use the return of the radiator or something like that. The system that has the most chance of being effective would be one that employs the difference in coolant temperature to and from the radiator, never mind the exhaust. It would reduce the effectiveness of the radiator, but then again it would also reduce the heat production of the engine. |
I have no doubt that energy recover from exhaust is usefull, but like you wonder will it ever be cheap enough? |
As for how much energy is in the exhaust, well at full throttle it's something like 40% heat energy going out the exhaust, at light throttle it's proportionally not much less but the temperature is lower so you can't collect as much. The TEGs nowadays can collect maybe like 2% of total fuel energy (adding to the ~30-35% engine efficiency) for modest single digit percentage improvement. That said, any load you take off the alternator counts extra because alternators are inefficient. |
So, with just 16 wires (one pound), we'd get a pull of 727 pounds. At a lever length of 1 foot, giving 727 pound-foot of force, that equates to 0.27 watt-hours. That's a couple orders of magnitude below your benchmark. |
World’s most efficient thermoelectric material developed
"The new material, which is based on the common semiconductor telluride, is environmentally stable and is expected to convert from 15 to 20 percent of waste heat to electricity." And for those ready to try this now: http://thermonamic.en.alibaba.com/pr..._Recovery.html Type: Thermoelectric Generator Hot Gas: Temperature > 673 K Output Power: 350 W Open circuit voltage: 48 VDC Matched Load Output Voltage: 24 VDC Matched Load Output Current: 15 A Internal Resistance: 1.6 Ohm Dimension Size: 595 mm * 140 mm * 265 mm Weight: 17.8 Kg For those wanting to start out smaller: http://www.ebay.com/itm/Thermoelectr...-/251817363025 Dimensions: hot side - 62 x 62 mm; cold side - 62x62 mm Produces 13 W matched load. Temperature differential: Tc = 50 Celsius; Th = 280 Celsius. U-oc - 3.4 V R-in - 2 Ohm R-load - 2 Ohm U-load - 1.33 V Pretty expensive technology though, considering you'd need about 10 of the smaller units above to produce vehicle voltage. So you're looking at an initial investment of about $800 to produce a measly 13 watts maximum. |
My plan is to use the exhaust heat to preheat water to just below its latent heat of vaporization. I'll then use a new ECU that'll control all the normal engine components (fuel injector, spark timing, etc.) but also control a water injector in the intake manifold.
That injection water, being at such a temperature from the exhaust that it's just about ready to flash to steam, will absorb heat in-cylinder and flash to steam. That has a couple advantages... it'll act as an octane boost, it'll slow down the lean burn so it's less explosive, it'll act as internal cooling and it'll contribute to cylinder pressure (and thus engine output). The trick is to get the water hot enough that it's just about ready to flash to steam before it's injected, so it flashes quickly once in the cylinder, to inject it in a fine enough mist that it can absorb heat quickly, and to inject enough to contribute to cylinder pressure while not so much that we're washing the oil off the cylinder walls. The new ECU will have a fuel map and a water map, so it'll be easy to tweak things just right. I'd use direct injection of the water, but my cylinder is so tiny that there's not a lot of room in there. Direct injection would let me time the water injection to just after combustion initiation, so the water follows along behind the flame front, absorbing the heat and flashing to steam. But unless I can find an exceptionally tiny injector, there's no way I can fit it in. |
That underlines my doubts.
350 Watt and 17.8 kilogram means less than 20 Watt per kilogram, and the cooling side has not even been constructed then. I have a Seebeck element like the one in that link but the power output is disappointing. You can use a Peltier element as an efficient heater or semi efficient cooler, but it is quite inefficient at producing power from a temperature difference. To my regrets, but nonetheless. |
0.268 = 200W/746W ...or... about 1/4-1/3 Hp.
