EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Mountain driving with Honda VX (https://ecomodder.com/forum/showthread.php/mountain-driving-honda-vx-13701.html)
oldertech 06-28-2010 01:02 AM
We just got back from the mountains of Colorado. With no MPG reading devices, I'm wondering... I know that coasting in idle is a way to make maximum efficiency down hills, but when the hills are mountains, you have to stay in a gear to hold the car from going too fast, and not burning up your brakes.
My question: Coasting down a mountain in gear in a '92 VX - are you burning gas? Or is gas shut off to the injectors if no power is needed?
As it was, we got 47 MPG driving home to Kansas at 75 MPH with AC on a lot of the way. Sure need to add a MPG computer to know what it really is doing all the time.
Scott
SVOboy 06-28-2010 01:14 AM
If you're engine braking you will not be using gas.
Have you thought about picking up an MPGuino yet?
bestclimb 06-28-2010 02:11 AM
you can feel the deceleration fuel cut off. As you are coasting down in gear with (3rd is shows up well in the honda) as you get down to about 1000 rpm you will feel the decelration from the engine braking stop. you can pick up a replacement instrument cluster with a tach for 30 bucks from a u pick a part, and install a wire off the speedo when you install it for the mpguino. It literaly takes less than 1 hour to both. Assuming you have a 5th gen honda.
user removed 06-28-2010 07:33 AM
Considering the average speed and AC use, I would consider 47 MPG to be about the optimum mileage you would get.
I would probably get about the same around here where it's fairly flat.
With AC on fuel shut off is about 1200 RPM, so you want to use the proper gear to maintain your downhill speed. Probably 4th or 5th depending on the grade.
When climbing you can stay in lean burn if you can maintain a manifold vacuum of over 5 inches. On grades that require downshifting for the down slope, the corresponding up slope would be difficult to climb at any decent speed while maintaining 6 inches of vac.
I would say the major factor in your mileage was your high average speed, much more so than the grades you encountered.
PS VX had a factory tach.
regards
Mech
oldertech 06-28-2010 09:47 AM
MPGuino
Sure have thought about MPGuino. Where do I get one and where is the most comprehensive info on how to install/use?
Scott
oldertech 06-28-2010 06:56 PM
That funky gas tank
The prime reason I'd like a mileage computer is that gas tank. For a car that is so carefully thought out to get high mileage, the regular means of checking, by dividing the gallons filled by the mileage driving is really, really hard to consistently do. If you stop filling the tank as soon as the pump clicks off, you are short about 2 gallons. If you trickle, trickle, trickle, you can go to a place that I named, "hyperfill." When I "hyperfill" the tank, I can go 200+ miles before the gauge drops from F.
I've looked at the tank design and it seems the filler tube is below the top of the tank. So when we trickle, we are kind of forcing fuel into the expansion area? Has anyone else acknowledge this in the VX? We had a Del Sol, and never had wacky filling issues.
By the way, I've read that the '92 VX has a 12 gallon tank, and the '93-'95 has a 10 gallon tank. Can anyone verify that?
Scott
NachtRitter 06-28-2010 07:03 PM
I can verify that my '94 has a 10 gallon tank, according to the manual that came with.
bestclimb 07-07-2010 02:59 AM
Scott
http://opengauge.org/mpguino/
The install is pretty easy, there are a few of us using them in 5th gen civics, the install is pretty painless. If you require a bit of guidance just do a search in the DIY or instrumentation forums or ask.
in my DX filling to the first click, I can go about 150 miles (50+mpg) before I come off the full mark. The tank 11.9 gallons. the first 3 gallons gets it off the full mark. The next 3 brings it to the half way point. 3 more drops it to the empty mark. and the last three just about on E to sputter.
user removed 07-07-2010 06:47 AM
I cut a piece of 2X4 with a angled edge. When I pull up to the pump I drop it in front of the left rear tire, and raise that end up slightly.
Consistent fill ups and about 50-60 miles range to the same point on the gauge when it gets to about 400 miles on the odometer.
One day I will carry some extra fuel and run it out to see what the gauge reads, but the way the needle oscillates, you can probably get a pretty good idea when it stops moving altogether. I think one time I got over 9 gallons in it but I don't like to run in tank electric fuel pumps dry. In my opinion since they are cooled by the fuel, it could shorten the life of the pump.
regards
Mech
Lovemy92vx 05-05-2015 11:55 AM
Found this thread trying to figure out how the tank is shaped and how the gas is measured.
The gauge drives me nuts. First because of the way it drops at a certain point when you think it's getting better mileage and then you have to wait for the drop. Why?
In the recent past I knew I was getting 47 plus mpgs regularly when the needle was just above halfway or roughly 200 miles. I've been having trouble achieving that mpg after lots of major maintenance and so have been watching the needle very closely.
Also, does it make sense that the car should hesitate when the tank is less than a quarter full? I've been encouraged to get the best mpg evaluation, run the full tank. I was filling up at a Shell station (using 85 octane-bad or good BTY) but I started getting short fills and splash overs. This has happened at another station. I switched to a small corner store to support a local business and liked the pump but I think the gas was bad.
I thought that gas might be the cause of a hesitation I feel right about where you want to shift (2000 rpm unless I need to get going). That Seemed to make a difference in power, my mpgs looked great on a highway trip at 60 mph from Denver to Colorado Springs. I really wanted to fill up after the first 100 miles because the needle barely budged, but resisted. It will be a good tank since I'm around 350 now and I feel like I'm right above that last darn drop on the gauge.
But now even with the better gas, the hesitation is evident to me again at least (my mechanic can't feel it when he drives it).
Any idea if gas level can make the engine hesitate?
I finally found a Conoco that bubbles up so I can hear it then the pump automatically stops. That will be my pump for three tanks.
Chrysler kid 05-08-2015 02:15 PM
The vx had harsh transitions from lean burn to normal to 16v. The hesitation is common at 2k rpms from what I've seeN on honda tech.
The gas gauges on Hondas are not very accurate, turn left and the gas gauge goes down, turn right and the needle goes up.
Assuming your car is up to date on maintenance and has clean egr passages and idles fine you should be getting consistent tanks of gas. I prefer a vacuum gauge to accurately tell me *remind me* how much throttle I'm using. You would be suprised how much difference a centimeter of pedal pressure hurts or helps your gas mileage.
So since I don't know your cars history I'll remind the tune up
ngk plugs
ngk wires
clean egr and idle air control valve
fuel filter
I would also suggest marvel mystery oil into the gas tank. $5.99 at any parts store for a 32oz jug
Lovemy92vx 05-08-2015 10:27 PM
Thanks Chrysler Kid.
I justed posted an extensive progression of maintence, part replacement, diagnostics if you're interested.
It's at 92VX seeking 50+.
