EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   mpg reporting backwards? 95 saturn (https://ecomodder.com/forum/showthread.php/mpg-reporting-backwards-95-saturn-21504.html)
wasilvers 04-18-2012 08:10 AM
I hooked up my mpguino yesterday and tested it out. The miles per hour are right on (with the speedometer) so I'm sure the vss input is right. The instant mpg screen seems to read backwards, when i accelerate, the mpg goes up in the hundreds, when i coast it goes down to single digits, and acceleration will bring it up again. Any ideas on what to adjust?
I have a 95 Saturn sl1 (1.9 liter 4 cylinder. I am certain I tapped an injector wire from the ecu. I have 12 volts, but must redo the '+' side because I didnt read it should he an always on connection.
Thanks for any help!
Will
nickdigger 04-19-2012 12:31 AM
Check the InjTrg 0=Dn 1=Up, in your setup screen, and change the value.
wasilvers 04-19-2012 10:18 AM
Thanks! that gets me close - now I have another problem... - I'll start a new post with it.
wasilvers 04-19-2012 10:28 AM
pad for post count so I can post a youtube vid of my problem
wasilvers 04-19-2012 10:29 AM
pad#2 for post count so I can post a youtube vid of my problem - thanks for patience
