EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   mpgguino problem (https://ecomodder.com/forum/showthread.php/mpgguino-problem-31579.html)
user102 03-21-2015 04:14 AM
mpgguino problem
Hi I have a mpgguino installed on a civic ek3 1.5l from Europe but I am getting problems with the readout.
1. Despite several calibrations after 1500 miles the vss/mile is either to low or to high and is consistently at least 20 % off the odometer reading.
2. Microsecond/gallon is a bit more accurate but Is still a challenge to get it within 10 % of the pump gallons because its either to high or to low.
Any suggestions ?
