Old 12-01-2008, 09:40 AM   #1 (permalink)
MR2 Turbo - '93 Toyota MR2 Turbo
90 day: 28.28 mpg (US)
Can I use 6-conductor RJ11 cord for Spiffie kit??
My spiffie.org MPGuino kit is on the way and should be here this week. I am having a hard time finding a nice black rj11 cord that is 4-conductor. Does anyone know if I can use a regular telephone cord that is 6-conducter because those are easier to find locally? If not does anyone know a good place to get a 4-conductor black rj11 cord? Thanks.
ERIK
Old 12-01-2008, 02:58 PM   #2 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 39.49 mpg (US)
It depends on whether your kit comes with a 4 pin connection, or a 6 pin connection. If it's a 4 pin, then a 6 pin wire might not physically fit in the socket. You might be able to trim off the ends on the wire to make it fit if that's the case though.
Old 12-01-2008, 03:45 PM   #3 (permalink)
The kit says it uses 4-conductor wire. But from my reasearch it seems like rj11 connectors are all the same. But the wire is different. So I was thinking that a 6-conductor might plug into the rj11 jack with the kit and just have 2 wires that arent being used.
ERIK
Old 12-01-2008, 04:21 PM   #4 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
This might help : LINK
Old 12-01-2008, 04:57 PM   #5 (permalink)
McTimson's Avatar
Looks like you're absolutely correct. I didn't realize they were the same size physically. So yes, you can use a 6 conductor wire, you'll just have 2 wires that don't get used.
Old 07-22-2009, 05:14 PM   #6 (permalink)
Just FYI for anyone reading this thread. I am using a regular phone cord. You just need to make sure it has atleast 4 wires in it. Alot I found around my house only had 2 wires. I ended up finding a nice black phone cord with 4 wires at Home Depot. Works very well.
Sterling Kit Car cfg83 Aerodynamics 33 12-11-2012 03:50 AM
DIY - Front Camber Kit SVOboy DIY / How-to 1 12-05-2008 12:52 PM
Diesel electric kit car, anyone? R. Q. Riley's latest takes shape (and looks good!) MetroMPG EcoModding Central 11 10-07-2008 02:52 PM
Newbee with hydrogen kit mechanic999 EcoModding Central 20 05-27-2008 02:17 AM
electric bike kit - hub motor bennelson For Sale 6 05-19-2008 09:52 PM
