MPGuino 1991 AUTOMATIC
I can't find anything about hooking this to an Auto trans car (1991 geo metro 1.0), I'm quite sure I have the pos, grnd and injector connections correct but the VSS is different than the manual cars. My car has a separate VSS in the transmission with 2 wires going to it I tried both of them and the first one didn't seem to do anything and the second one did once the speed was brought up (on jack stands for testing).
I know my speedometer is off due to the 13" tire/wheel upgrade (I calculated 8.3333% difference). I adjusted the VSS pulses per mile to 7524 from 8208 but now that I think about it this probably isn't right but I didn't want to start with a value that I know is wrong. How much of an adjustment does this parameter take for a change like I have? I didn't see (on the wiki or here) a way to get the MPGuino to display the VSS pulse count either or I could use that? if this is possible how is it done? I get no instantaneous MPG reading until I get up to about 40MPH and then if I accelerate long enough the reading drops until it gets all the way down to zero and stays there until I lift completely off the accelerator-then it pops back up to 999- any ideas why it would do this? (I know 999 means coasting in gear already) |
Dunno if this thread will help or not with the vss. But you want the one in the speedo, not the one from the trans I think (different signal strengths).
http://ecomodder.com/forum/showthrea...tml#post108671 ^89 metro w/auto |
OK I found the yellow/green wire under the dash on the drivers side above the fuse block ( the ECU is right there too). That made everything work much better and I was able to get a rough speed calibration for my car of 8100 pulses ( I went 50 MPH on the speedo and tried to get MPGuino to indicate 54.16 for the 8.333% difference) close enough for now.
It did freeze up on me once and there is one part on the back that I noticed gets a little warm is this normal or might I still have some connection problem? So, from here, if I understand this right, once I get actual mileage from the next tank I start adjusting the injector input until I can get actual and MPGuino mileage to match right? |
Here is the calibration page, it should spell it out, might want to be sure all connections are solid first and I would just leave it on the custom screen while driving to reduce the possibility of freeze in mid calibration.
Mpguino calibration - EcoModder |
Thanks, don't know how I missed that page with all the time I've been looking at stuff for this- that's just what I was looking for.
good deal :)
The unit was working good today but it froze about 5 miles from home.
What causes it to freeze and is there a way to stop it from happening? What is the best course of action to get it working again without wiping out the memory? There is a part (op-amp I think?) in the picture below that gets too hot to touch for more than 1 second- is this normal or a sign of a problem? http://ecomodder.com/forum/member-ro...188-guino2.jpg |
that is the voltage regulator, it can get warm. I don't have a pat answer on the freezing, can you describe the conditions when it happened?
I would turn the brightness down (with the middle button) to like 1, and that should keep the regulator happier anyway. |
I keep the brightness set at one already.
Today it happened (I think) right after I hit a good size bump in the road in a construction zone (the 40 psi in the tires makes bumps feel a little worse than they really are). So disconnect/ reconnect the power the only way to get it going again? |
I finally got around to the last resort yesterday - hooking the unit directly to the battery, and it looks like that has solved all the issues I was having. It has worked 2 days now and about 65 miles which is a new record for me.
It was so bad last week I just unplugged it for about 4 days because it would freeze and/or reset itself almost continuously...I was starting to think something was wrong with it. |
Well, maybe NOT. It froze 3 times and reset it self 2 times in about 46 miles of driving today.
There's nothing else I can think of to try on my end so maybe there's just something wrong with the unit I have??? |
Reset 3 times and froze 2 times again during my regular (46 mile) commute (probably would have been more but I got frustrated and just unplugged it for the last 10 miles) and I can't find anything that correlates to when or why it happens.
Maybe I should just give up, but it's such a fun toy WHEN it works... |
can I suggest to dissect the plug and solder/recrimp?
If I thought there was any chance it would solve the problem I would but I was very careful when I put the connectors on so I know the connections are good and they aren't touching one another, other than that I don't think anything else matters.
I also don't want to mess with those tiny connectors again, I don't think they would survive much monkeying around- I think I could buy new connectors at Radioshack right? It reset 3 times today and froze 1 time. |
Yah those connectors are kind of tiny. If you have an old computer it is the same plug as is on a 3.5" floppy, and there are usually a couple unused ones in a typical computer.
It would be good to try it in another car too, and you can ask amy to reflash it (send it back with a S.A.S.E.) and drive it around a bit. |
