Mpguino acting weird
Ok, so I had the mpguino working the other day straight wiring everything together, so today I put all the components on board to rewire it.
Now it doesn't work 1. Would putting the led in wrong cause this (doubtful, I shorted it to test it anyway) 2. Has anyone seen there screen do this before After turning it on, the screen stays blank for a couple of seconds, then the top row of characters displays all 16 boxes, then I can see that the screen is updating really fast but not showing anything. 3. Did I burn something out during my soldering? (I don't think I did) What could have shorted to make this happen? I'm going to check over my component board and wiring again, but I was wondering if anyone has had this happen before Sorry, yeah I going to recheck my wiring right now, but I want to get some other opinions in case everything still looks right. |
I ran into this today actually. In my case I had the RS and Enable lines crossed. Triple check your LCD -> 'duino connections: RS, Enable, and Contrast are close to each other on both, but are in different orders. I found it easier on my board to fix it in software :)
Oh, and even if the LCD is wired wrong or not even powered, the 'duino's LED(s) should light up if its powered. Good luck. |
Yeah, might have some wires crossed. Or else try reflashing the guino.
