12-29-2012, 08:39 AM
Scangauge E fillup entry
Hello,
Have been using scangauge E for a month now and I really like it, but the only problem I have with it is price input when I make a fillup. Digits for price are changing realy slowly .1 in about 3 seconds. Have anyone else got same problem?
12-29-2012, 10:22 AM
I normally don't bother updating the gas cost. Its only used for the money calculation gauges which I never use. I also don't bother calibrating my scangauge after ever fill. Once I get it close enough for me, I just leave it.
12-29-2012, 11:14 AM
I agree with your points, but it is so much nicer to see each trip cost
About calibrating: It is no problem to make adjustments in each fillup, to make it spot on... I managed to do it with 3 tanks, and now I am with in +/- 0,1 L/100KM
12-29-2012, 01:59 PM
You're describing slow digit changes when you HOLD the adjustment button? I'm sure you've tried tapping it repeatedly - does that work?
12-29-2012, 02:39 PM
Yes digits are changing slowly when I hold button, and yes, I tried tapping button, but it did not help either.
I am starting to think that it is some kind of firmware bug. Maybe somone else has seen that same problem?
12-29-2012, 04:54 PM
Not being able to speed it up by tapping is odd. I'd contact the company directly.
01-21-2013, 08:45 AM
So is this worse than the Scanguage II or the same slow method on both devices?
01-21-2013, 12:01 PM
amdown - did you contact the company about this? If so, I'm curious about what they said.
