Old 09-18-2012, 08:35 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
SignalGuru (App + OBDII interface)
Hello -
Found this article :
SignalGuru app helps drivers avoid red lights
Researchers at the Massachusetts Institute of Technology have developed a system that uses dashboard-mounted smartphones to help drivers avoid red lights and reduce fuel consumption.
The app called SignalGuru predicts when a traffic signal is about to change, and the speed that should be driven when approaching an intersection in order to cruise through without stopping.
"The stop-and-go pattern that traffic signals create increases fuel consumption significantly," said Emmanouil Koukoumidis, the scientist behind the app.
I say OBD II because I see this at 0:05 on the video :
CarloSW2
American Solar Energy Society
Old 01-08-2013, 12:16 PM   #2 (permalink)
there's a newer application indicating optimal speed. search for ampelmeter.
