EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   MPGuino, "current mileage" questions. (https://ecomodder.com/forum/showthread.php/mpguino-current-mileage-questions-20983.html)
Jonathan6229 03-14-2012 04:56 PM
So, I just put a fuel cutout relay and separate push to start switch in my car, to make things easier for EOC. I also ran a start sw right from the start relay to a ignition wire that is hot with the key in the ON position. Can I change my MPGuino settings, so that if I sit at stoplight for 2 minutes or so, the current mileage doesn't reset? It really seems to but related to the time I have the engine of, so I suspect that it's a setting I can configure, but I don't know which one it would be.
Ecky 03-22-2012 10:14 PM
Yes, definitely. In setup, change "current Trip Reset Timeout" to a larger number. You could also change it in the code (should be easy to find) if you reflash your MPGuino with the latest code.
