Mpguino died
Hi all my mpguino screen froze...so I unplugged the power to reset, but I don't think when I reconnected it that it made a positive connection so it damaged something.
There used to be information about this problem but now I'm having it, I can't find anything. As of now my mpguino is lit up with a blank screen. |
http://ecomodder.com/forum/showthrea...ight-6623.html Haven't time to read through it...not sure if it will help. |
Found what I was looking for
What if my LCD text is messed up or frozen? First, try power cycling the unit. Unplug the power source, wait 20 seconds, then plug it back in. This wait period is important. If you plug it back in too soon you may freeze the bootloader in a loop and you will have to reload the program: [8] Copy and paste the code into the Arduino 0011 Alpha program which you can download from: [9], Then "upload to I/O board" on your MPGuino using a USB cable. The correct baud rate for upload is 19200, on the spiffie kit MPGuino. |
