EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   MPGuino Guerilla build. (https://ecomodder.com/forum/showthread.php/mpguino-guerilla-build-21884.html)
thebob 05-12-2012 08:31 AM
Ok the plan is to get ...
1 x Deal extreme Arduino Compatible Nano V3.0 for $16.90
1 x Deal extreme 16 x 2 Character LCD Display Module with Blue Backlight $4.70
And then solder on a couple of zenners a few resistors a transistor and 3 switches. Like the wiki
Load the code from.
opengauge . mpguino.cpp
Stick it in a box and I'm good to go.
Any suggestions? Anything I've missed?
thebob 05-13-2012 08:54 AM
The MPGuino release one workspace thread lists, 2 100k resistors but the schematic says they are 50k. Are 100k OK?
nickdigger 05-13-2012 11:52 AM
Either one should work.
stewie 05-22-2012 09:39 PM
Load the code from.
Where are the instructions to putting MPGuino from few parts you listed above? What does it mean "MPGuino Guerilla build" ???
Copyright ©2000 - 2021, vBulletin Solutions Inc.
