05-04-2012, 01:04 PM
FNG
SeaFoam on +110k auto..?
Does anyone have any success/horror stories, or, just words of wisdom on seafoaming an old car? I have an '02 Subaru Forester that could use a pick-me-up but, I'm worried about dislodging old gunk and build up in the engine that has the potential to do more harm than good if not evacuated properly.
05-06-2012, 12:54 PM
Elise - '13 Hyundai Elantra GLS
I don't know much about the science behind it, but I recently used Seafoam in the gas tank of a car with 183k miles with no negative effects. I'm not sure how much of a measurable benefit it gave, although it seemed to run more smoothly afterwards.
06-04-2012, 02:52 PM
If you use it in the engine oil, change the oil shortly afterwards. It does work somewhat but it's no substitution for taking things apart and scrubbing. The biggest place that needs to be cleaned is the intake manifold which becomes gunked up from the PCV system.
06-05-2012, 09:42 AM
i have always had good luck with it until recently used it in the wife's rav4 with 120000km in it and now the valve seals are leaking pretty badly... but it runs and starts smoother...
06-05-2012, 09:53 AM
Cyborg ECU
This sounds more like coincidence than cause/effect to me. Probably your old seals were about to go anyway, or you noticed the leak because you were paying closer attention. I bet they're not related.
06-05-2012, 10:05 AM
possibly? but its blowing smoke on startup and it never did before? I just assumed that it cleaned some gunk out that was stopping the seals from leaking? I used it in the intake and the oil, and then did an oil change. Could thinner oil cause leaks?
06-05-2012, 11:32 AM
Cyborg ECU
If right, then the sea foam helped you diagnose a problem needing attention. If wrong, then you have still correctly noticed a leak needing attention. The sea foam was more like a diagnostic tool than cause. I don't imagine the thinness of the oil could cause instant leaking, though maybe long term if it increases wear on parts. I wonder what others with more experience think.
06-05-2012, 12:15 PM
thinner than recommended oil could cause problems. it is also possible that the seafoam did clear away some gunk and now allows oil to seep down the valve. personally, because i have always had used cars that are over or well over 100k miles, i use 10-40 oil. it helps with valve tick and smoking.
06-05-2012, 08:44 PM
#9 (permalink)
seafoam in the gas tank is probably a good idea.
changing the fuel filter is a better idea.
sea foam in the crankcase is a good idea if you have sticking lifters or something like that. I would not expect sea foam to give a "pick me up".
what are the symptoms you are subaru is showing?
06-05-2012, 11:51 PM
#10 (permalink)
Seafoam maybe hard on plastic lines
buddy of mine used seafoam on his 87 trailblazer and soon his feul injection "spider" (lil hoses that throw the fuel to cyclinders on the 4.3 v6) where all hard and developed pin holes after new feul pump, line then finally the "spider" and supply hoses he only had the problem after he added the seafoam..not sure was cause but he blames it lol
