MPGuino install in a '91 Mustang?
Would this be the same process as installing it in a civic? Just find the VSS signal, injector signal at the ECU then using a 12v power from somewhere in the fuse box? I really don't want to go through the firewall into the engine compartment.
I found this diagram but, I'm not to sure which injector to go after? I see the VSS signal so I'll just tap into that, but which injector should I use?
http://www.veryuseful.com/mustang/te...ng_Diagram.gif |
From the Wiki
Copyright ©2000 - 2022, vBulletin Solutions Inc.
