mpguino keeps resetting
It seems that my mpguino keeps resetting about every 7 or so car trips. It is very annoying that this keeps happening. All 4 wires were soldered so its not like there is faulty wiring.
What do i do, as my kit was purchased pre-assembled with no usb port to flash my chip in case the newer software would fix this problem. |
If it isn't too old, Amy will reflash it if you send it back with a note and a SASE.
Thanks, Jon |
SASE = Self Addressed Stamped Envelope , will return the unit in that once we take a look at it.
PM Sent Always do what you can to make sure it isn't a hookup issue of course. |
