MPGuino with LCD Philips PCD8544 (?)
Hi,
i want to make MPGuino work with LCD Philips PCD8544 (Nokia 3310) it's possible?...or it's possible but hard to adapt MPGuino code? :confused: sorry, but i'm new at arduino. =/ Thanks |
7 Attachment(s)
70% done :D
30% with error: can't see "cursor" in SETUP. (foto: 7) big font with error. (foto: 6) function names. (foto: 2, 3) ... need help for big font and for SETUP. have big font like in (foto: 5) but only for "123456" string. how to correct big font? in SETUP how to make "cursor" become visible? Thanks, BR |
LOL, nice hacking there :) though I don't know anything about that display, does it have built in or user defined fonts/glyphs or is it draw your own characters from bitmaps every time?
For $10 more I would consider this, with 1:1 aspect ratio and a lot more real estate and a backlight. Graphic LCD 128x64 STN LED Backlight - SparkFun Electronics |
i'm new at all this. that why i'm using old 3310Lcd. i think that it is user define font. (normal font 5x7) |
Do you have a link to your code example? Not sure where you started. If it is all one file you can cut and paste into a post too.
despite all the tests..
now i'm using two libraries for Philips PCD8544 you want this or MPGuino code? |
I was just curious how you did the 123456 part, I hadn't looked into graphical LCDs much prior.
based in another code:
static const byte ASCII_Large[][24] = {{0x00, 0x00, 0xf8, 0x1f, 0xfc, 0x3f, 0x0e, 0x70, 0x07, 0xe0, 0x03, 0xc0, 0x03, 0xc0, 0x07, 0xe0, 0x0e, 0x70, 0xfc, 0x3f, 0xf8, 0x1f, 0x00, 0x00}, // 0 {0x00, 0x00, 0x04, 0x80, 0x04, 0xc0, 0x06, 0xc0, 0x06, 0xc0, 0xff, 0xff, 0xff, 0xff, 0x00, 0xc0, 0x00, 0xc0, 0x00, 0xc0, 0x00, 0x80, 0x00, 0x00}, // 1 {0x00, 0x00, 0x18, 0xe0, 0x1c, 0xf0, 0x06, 0xd8, 0x03, 0xcc, 0x03, 0xc6, 0x03, 0xc3, 0x83, 0xc1, 0xc6, 0xc0, 0x7c, 0xc0, 0x38, 0xc0, 0x00, 0x00}, // 2 {0x00, 0x00, 0x08, 0x10, 0x0e, 0x70, 0x87, 0xe1, 0x83, 0xc1, 0x83, 0xc1, 0x83, 0xc1, 0x87, 0xe1, 0xce, 0x73, 0x7c, 0x3e, 0x38, 0x1c, 0x00, 0x00}, // 3 {0x00, 0x00, 0xc0, 0x07, 0xe0, 0x07, 0x70, 0x06, 0x38, 0x06, 0x1c, 0x06, 0x0e, 0x06, 0xff, 0xff, 0xff, 0xff, 0x00, 0x06, 0x00, 0x06, 0x00, 0x00}, // 4 {0x00, 0x00, 0xff, 0x38, 0xff, 0x78, 0xc3, 0xe0, 0xc3, 0xc0, 0xc3, 0xc0, 0xc3, 0xc0, 0xc3, 0xe1, 0x83, 0x73, 0x03, 0x3f, 0x03, 0x0e, 0x00, 0x00}, // 5 {0x00, 0x00, 0xc0, 0x1f, 0xf0, 0x3f, 0x38, 0x63, 0x8c, 0xc1, 0x86, 0xc1, 0x83, 0xc1, 0x83, 0xc1, 0x03, 0x63, 0x00, 0x3e, 0x00, 0x1c, 0x00, 0x00}, // 6 {0x00, 0x00, 0x0f, 0x00, 0x0f, 0x00, 0x03, 0xe0, 0x03, 0xfc, 0x03, 0x1f, 0xc3, 0x03, 0xf3, 0x00, 0x3f, 0x00, 0x0f, 0x00, 0x07, 0x00, 0x00, 0x00}, // 7 {0x00, 0x00, 0x18, 0x38, 0x7c, 0x7c, 0xe6, 0xe6, 0x83, 0xc3, 0x83, 0xc1, 0x03, 0xc3, 0x83, 0xc2, 0xc6, 0xe6, 0x7c, 0x7c, 0x38, 0x38, 0x00, 0x00}, // 8 {0x00, 0x00, 0x78, 0x00, 0xfc, 0xc0, 0xc6, 0xc1, 0x83, 0xe1, 0x83, 0x71, 0x83, 0x39, 0x83, 0x1d, 0xc6, 0x0e, 0xfc, 0x07, 0xf8, 0x03, 0x00, 0x00}, // 9 {0x00, 0x00, 0x0c, 0x00, 0x12, 0x00, 0x12, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // deg {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00} // space }; // this function is designed to translate // the 16x16 character string to start at the // specified pixel origin (x,y) coordinate void Nokia3310Display::largeStringOriginXYPixel(int x, int y, char *t) { byte temp_ASCII_Large[6][36] = {{0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00}, {0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00}, {0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00}, {0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00}, {0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00}, {0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00} }; // max four character string translated across three banks int y_bank; byte shift_in_a = 0x00; byte shift_in_b = 0x00; int x_index; byte mask_1 = 0x00; byte mask_2 = 0x00; int temp_index = 0; int string_index = 0; int ascii_lg_index = 0; // determine the origin y bank y_bank = y / 8; // calculate the array layout for the string for (string_index = 0; string_index < 6; string_index++) { // pick out the character in the string, translate to the x dim of ASCII_large // something like x_dim char[i] - 0x20 // move through ASCII_Large two y dim bytes at a time int ascii_large_index = 0; // assign to two most sig bytes of temp_ASCII_Large if (string_index < 6) { if (t[string_index] == 0x20) ascii_lg_index = 11; else ascii_lg_index = t[string_index]-0x30; } else ascii_lg_index = 11; for (temp_index = 0; temp_index < 36; temp_index++) { // shift_in_a = 0x00; // shift_in_b = 0x00; /************************************************** *********** THE PROBLEM IS THAT I AM NOT INCREMENTING THE FIRST DIMENSION OF temp_ASCII_Large AS I GO THROUGH EACH CHARACTER IN THE STRING ************************************************** ***********/ temp_ASCII_Large[string_index][temp_index] = ASCII_Large[ascii_lg_index][ascii_large_index]; // Serial.print("ascii_large_index: "); // Serial.print(ascii_large_index, DEC); // Serial.print("\ttemp_index: "); // Serial.print(temp_index, DEC); // Serial.print("\tASCII_Large: "); // Serial.println(ASCII_Large[0][ascii_large_index], HEX); // shift_in_a = ASCII_Large[0][ascii_large_index] & 0x01; temp_index++; ascii_large_index++; temp_ASCII_Large[string_index][temp_index] = ASCII_Large[ascii_lg_index][ascii_large_index]; // Serial.print("ascii_large_index: "); // Serial.print(ascii_large_index, DEC); // Serial.print("\ttemp_index: "); // Serial.print(temp_index, DEC); // Serial.print("\tASCII_Large: "); // Serial.println(ASCII_Large[0][ascii_large_index], HEX); // shift_in_b = ASCII_Large[0][ascii_large_index] & 0x01; temp_index++; ascii_large_index++; // Serial.print("temp_index: "); // Serial.println(temp_index, DEC); } // for temp_index // now translate to the new y pixel value temp_index = 0; while (temp_index < 36) { // first for each of temp_ASCII_Large[_][temp_index to temp_index + 2] // PROBLEM: The masking steps are wrong when y % 8 = 0; FIGURE THIS OUT mask_1 = temp_ASCII_Large[string_index][temp_index] >> (8-(y % 8)); mask_2 = temp_ASCII_Large[string_index][temp_index + 1] >> (8-(y % 8)); // Serial.print("temp_index: "); // Serial.println(temp_index, DEC); // Serial.print("\t\t"); // Serial.print(temp_ASCII_Large[0][temp_index], HEX); // Serial.print("\t"); // Serial.print(temp_ASCII_Large[0][temp_index + 1], HEX); // Serial.print("\t"); // Serial.println(temp_ASCII_Large[0][temp_index + 2], HEX); temp_ASCII_Large[string_index][temp_index] = temp_ASCII_Large[string_index][temp_index] << (y % 8); // Serial.print("shifting: \t"); // Serial.print(temp_ASCII_Large[0][temp_index], HEX); temp_ASCII_Large[string_index][temp_index + 1] = temp_ASCII_Large[string_index][temp_index + 1] << (y % 8); // Serial.print("\t"); // Serial.print(temp_ASCII_Large[0][temp_index + 1], HEX); temp_ASCII_Large[string_index][temp_index + 1] = temp_ASCII_Large[string_index][temp_index + 1] | mask_1; temp_ASCII_Large[string_index][temp_index + 2] = temp_ASCII_Large[string_index][temp_index + 2] << (y % 8); // Serial.print("\t"); // Serial.println(temp_ASCII_Large[0][temp_index + 2], HEX); temp_ASCII_Large[string_index][temp_index + 2] = temp_ASCII_Large[string_index][temp_index + 2] | mask_2; // Serial.print("\t\tmask_1: "); // Serial.print(mask_1, HEX); // Serial.print("\tmask_2: "); // Serial.println(mask_2, HEX); // Serial.print("masking: \t"); // Serial.print(temp_ASCII_Large[0][temp_index], HEX); // Serial.print("\t"); // Serial.print(temp_ASCII_Large[0][temp_index + 1], HEX); // Serial.print("\t"); // Serial.println(temp_ASCII_Large[0][temp_index + 2], HEX); // Serial.println(); // Serial.println(); temp_index = temp_index + 3; } } // for string_index // display the string using LcdWrite gotoXY(x, y_bank); //LcdWrite(LCD_D, 0x00); for (int char_index = 0; char_index < 6; char_index++) { x_index = 0; while(x_index < 36) { // Serial.print("x_index: "); // Serial.print(x_index, DEC); LcdWrite(LCD_D, temp_ASCII_Large[char_index][x_index]); // Serial.print("\t"); // Serial.println(temp_ASCII_Large[0][x_index], HEX); //LcdWrite(LCD_D, 0x00); x_index = x_index +3; } // Serial.println(" "); //LcdWrite(LCD_D, 0x00); } gotoXY(x, y_bank + 1); for (int char_index = 0; char_index < 6; char_index++) { delay(100); x_index = 1; //LcdWrite(LCD_D, 0x00); while(x_index < 36) { // Serial.print("x_index: "); // Serial.print(x_index, DEC); LcdWrite(LCD_D, temp_ASCII_Large[char_index][x_index]); // Serial.print("\t"); // Serial.println(temp_ASCII_Large[0][x_index], HEX); //LcdWrite(LCD_D, 0x00); x_index = x_index +3; } } // for char_index // Serial.println(" "); //LcdWrite(LCD_D, 0x00); gotoXY(x, y_bank + 2); for (int char_index = 0; char_index < 6; char_index++) { x_index = 2; //LcdWrite(LCD_D, 0x00); while(x_index < 36) { // Serial.print("x_index: "); // Serial.print(x_index, DEC); LcdWrite(LCD_D, temp_ASCII_Large[char_index][x_index]); // Serial.print("\t"); // Serial.println(temp_ASCII_Large[0][x_index], HEX); //LcdWrite(LCD_D, 0x00); x_index = x_index +3; } //LcdWrite(LCD_D, 0x00); } // for char_index } |
void display1(int x, int y, char *t){
lcd1.largeStringOriginXYPixel(x, y, t); } void doDisplayM() { display1(0, 0, "123456"); } |
ok, it "looks" like you are sending bitmaps for each character to the LCD when you want to display them, and you have bitmaps/fonts defined from 0-9 and degree and space, so if there is still room in memory you might be able to add character fonts to that ASCII_Large array and figure out how to map character values into it when processing a display string. The temp buffer is only good for 6 characters of course.
Did you write this or where did you find it? I usually use PROGMEM for "large" tables FYI, so that they don't soak up a bunch of RAM. i.e. //creating the custom fonts: LcdCommandWrite(0b01001000); // set cgram static byte chars[] PROGMEM = { 0b11111, 0b00000, 0b11111, 0b11111, 0b00000, 0b11111, 0b00000, 0b11111, 0b11111, 0b00000, 0b00000, 0b00000, 0b00000, 0b11111, 0b00000, 0b00000, 0b00000, 0b00000, 0b11111, 0b00000, 0b00000, 0b00000, 0b00000, 0b11111, 0b00000, 0b00000, 0b00000, 0b00000, 0b11111, 0b01110, 0b00000, 0b11111, 0b11111, 0b11111, 0b01110, 0b00000, 0b11111, 0b11111, 0b11111, 0b01110 }; also using binary notation can allow you to visualize the font in the code sort-of. Here we have 5 8x5 characters. A thick line on top, a thick line on bottom, a thick line on top and bottom, a completely filled font, and a dot. from: http://opengauge.googlecode.com/svn/...no/mpguino.cpp |
at (foto: 6) tried to use same as you. but as you see something are wrong.
then i find this code (don't remember were, think it was about a termometer) |
