MPGuino Parts list
I pulled the partslist out of the release one thread, and its the only listing I have found that seems to be "here you go, buy this" and then i found issues.
list source : http://ecomodder.com/forum/showthrea...pace-2115.html Arduino - going to get an actual one because i could only find the idunio for 20+45 shipping list 2 5.1v zener diodes - 5.1v Zener diode what wattage? 1 2n3906 PNP Transistor - 2n3906 i was just going to get the first one 1 220 ohm resistor - 220 resistor found several, but what wattage 2 100k resistors - 100k resistor see above 3 tactile switches - SWT6-V3RD probably just 3 of these thanks for your help with the recomended wattages |
The resistors and diodes are being used in a signal function not power, so almost any wattage will do. 1/4W resistors are the most common. A 1/2W diode will be fine. The first PNP will be fine, as will those switches.
