MPGuino PiggyBack - Duemilanove
I've finally gotten started with putting together an MPGuino, but with a small twist. I'm too broke (read: cheap) to buy another arduino for this project, so I decided to make a plugin MPGuino module for my only arduino.
This is my first time designing, and etching PCB boards. I am completely uneducated, and have no experience with board layout and design. This first version isn't going to work out as I intended.. but i'm still going to populate it with everything minus the LCD to see if the functionality is there. Version 2 is going to have surface mount resistors/diodes for ease of tracks, that way I dont have to "over/under" solder some things. I'll update this thread with anything pertinent. Be patient, my mind picks up a new project every 10 minutes so I tend to jump around. Here is my first layout design (done in 30 minutes during my CAD class today) http://lh5.ggpht.com/_vMcuB-6YZR0/TJ...Guino%20v1.jpg Here is the front side etching which turned out pretty perfect. http://lh3.ggpht.com/_vMcuB-6YZR0/TJ...2022.42.38.jpg Here's the bottom side. I had two broken tracks but luckily I have some conductive paint laying around so i'll tidy that up tomorrow. http://lh3.ggpht.com/_vMcuB-6YZR0/TJ...2022.43.41.jpg |
kewl!
do you know the sharpie trick? If some toner sticks to the paper? Or just freehand etch resist. |
As far as the two broken tracks, I think that's just my impatience on letting the sharpie completely dry. I'm pretty sure the etching fluid just washed it out. I have plenty of time between classes tomorrow to knock out a better design for v2. |
Seems like a lot of work & fabbing, just to plug into a Duemilanove. Especially if there's a v2.0 coming. On my Seeeeeduino, i just trimmed my leads & wires & crap to the proper lengths, and plugged them into the headers. To each his own, but i'm glad i read this since i learned there is a Sharpie trick out there.
