EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   MPGuino problem (https://ecomodder.com/forum/showthread.php/mpguino-problem-6134.html)
Coyote X 11-22-2008 10:17 PM
MPGuino problem (fixed)
Ordered a kit version MPGuino a month ago, it came in Thursday and put it together last night. Today I tried installing it. I wired it up to the wiring off the ecm and plugged it in and it came right up working. I started the car and it was showing the injector signal was working fine. As soon as I started to move the car it reset. So I turned it off and rechecked my wires and everything is properly wired up. I took the easy way out and jacked a wheel up so I could spin the tire in the garage. Any time I spin the tire and it gets a vss tick it resets or locks up. I messed with it for a few minutes before it corrupted the avr chip. So I gave up since it was getting cold out.
I had to reload the avr completely, it scrambled the bootloader even. Not a big deal I have everything I could need to work with Atmel chips. I am getting ready to figure this thing out. Other than checking the vss signal path is there any other ideas anyone has for stuff to check on?
Coyote X 11-22-2008 11:52 PM
Wasn't that hard to fix. The zener was no good. It was letting through about 8 volts. Swapped it for an extra I had laying around and it works now. I guess I am lucky the avr chip didn't let out it's magic smoke :)
Now the fun part of trying to find a 4 conductor phone wire and I am done. I had to borrow one from a neighbors phone to test it out with today. Tomorrow I will find a good wire somewhere and hopefully mount it in a box and be ready to use it.
I'll post pics after it is installed.
dcb 11-22-2008 11:54 PM
Not sure, but you might want to note the current brownout setting and try a different value.
http://ecomodder.com/forum/showthrea...html#post66234
But I would try a new bootloader and reflash the latest mpguino code (arduino 0011 pls) for starters.
orange4boy 11-26-2008 12:44 AM
Frozen, then dead. Can MPGuino be resurrected?
Having this recurring problem of freezing. The screen freezes and no buttons work. the only way to reset is to unplug and replug. Problem is today I unplugged and it wouldnt restart. dead screen. Even on the USB at home. Is this possibly the brownout thing being discussed here?
If so do I need to bootload it? I'm reading voltage on the board so it does not seem to be a power issue.
I'm running without alternator so perhaps I need a separate battery for it so this does not happen.
Thanks.
P.S. I know there is a lot to do here but perhaps we could set up a known issues page on the wiki to keep this all in one place. I'm willing to do some work on that if I knew where to start.
dcb 11-26-2008 05:30 AM
re: known issues page, please do.
re: dead, check all your connections, remelt all the solder joints, and note that you have to be real deliberate when hooking up the power (can corrupt the flash if power is flaky). Do you know how to reflash it? You might need to get Kevin engaged.
orange4boy 11-26-2008 07:18 PM
I'll check all my solders then try the bootload if that fails.
I did unplug and replug without waiting before I knew how important that was so perhaps I corrupted the chip that way.
Never done the chip programming before but I can handle it. Already have aurduino11. I need a parallel programmer though. Can this be done from a powerbook with no serial port? USB? I will pick up either parts or a new programmer tomorrow. If I need a serial port I guess I will have to use the old G3.
I'm not clear where to hook up the programmer though. do I need to solder some jumpers? Are there instructions somewhere. I will compile all of this for the Wiki If you (or kevin? who dat?) can point me in the right direction with the programmer to guino. It's one of the spiffie kits BTW.
Thanks a bunch.
dcb 11-26-2008 09:45 PM
kevin=spiffie=fundamentallogic.com
If it doesn't take a program from arduino then it might need a new bootloader.
orange4boy 11-27-2008 02:57 AM
Thread hijack complete sir!
When I try to upload the code I get a sketch size too big error. It's only 10 bytes too big.
Binary sketch size: 14346 bytes (of a 14336 byte maximum)
As always I'll see what I can do on my own.
If I had to cut something then the custom page would be it. What parts could be cut and where?
Would these kit boards fit a bigger chip without modification? I'd be happy to upgrade so more goodies could fit. And would the existing program run?
ADDED: I did it! MPGuino is alive! I found the cpu % display and cut it out. Had to chop out a little more further down. Hope it runs now.
dcb 11-27-2008 07:11 AM
huh? You are using arduino 0011? On which platform? It is supposed to fit without touching the code...
orange4boy 11-28-2008 02:04 AM
Yeah, I'm using 0011, on a G4 powerbook 10.5.5 and the Spiffie kit.
I managed to cut out something to do with the CPU% display and It seems to run fine. Arduino found an error related to the cut and I chopped that out too which seemed to work. Sorry, It sounds so brutal somehow to be chopping at your programming:o
It did freeze again today though. Could touching the board cause that? It's either that or deceleration. I better remove one of those variables eh?
I am loving all this though. It's a steep learning curve which I like. Thanks for all your advice and programming.
dcb 11-28-2008 05:21 AM
I've seen it (and other computers) freeze when touching the circuits. I'm just a little concerned that different platforms make different sized hex filed for the same avr platform. I think I can find 10 bytes easy enough.
orange4boy 11-28-2008 09:34 PM
I'm starting to think it's a voltage problem. It froze and / or reset a few times today, usually when I had a large load on the batteries. I am running without alternator and voltage drops under 12 sometimes. I will have to hook it up to a separate battery and in an enclosure to eliminate those possibilities.
Is there a minimum voltage where it resets or data is corrupted?
If that does not do the trick next possible cause would be signal issues, I guess, reading from other posts.
sevenspeed 12-14-2008 08:02 PM
reflashing? hardware needed?
I had no clue about waiting to plug power back in after unplugging. Will have to find the known issues page. It kept freezing or resetting on me and I would unplug it and plug it back in. I think it had to do with temperature as it didn't seem to have the problem after about 10 minutes (car is parked in a Michigan garage.) I'll have to take it in the house with me.
Well, today I did that and it died, no screen even with usb. What do I need to be able to reflash the chip aside from the arduino IDE 011? Do I need to make some sort of ciruit board? As long as it's simple I'll be fine. I'm good with electronics but have never etched a board or anything like that but could do the breadboard thing if it's not too many connections. I don't see anything burnt or a bad solder connection. I'm pretty good at soldering and I don't have any desoldering braid atm to try to get the LCD board off to check anything on that end. But when building I doublechecked all my soldering and of course had to add a bit more to a couple.
orange4boy 12-16-2008 02:46 AM
I had the same issue.
You don't need any hardware, just the arduino 011 downloaded and running and a usb cable. Cut and paste the code(sketch) from the mpguino google code page (in the wiki i think) into a new sketch in arduino then hit the "upload sketch" button with your guino hooked up.
If you get the sketch too big message then bug dcb to shorten it for you. There are a few of us that need a shorter sketch.
You have to wait 20 seconds before re-plugging if you disconnect the mpguino. I.m too busy to add this to the wiki right now.
sevenspeed 12-16-2008 02:39 PM
much appreciated
Thanks I really do appreciate it. I hope to be able to contribute myself, I should be able to help the Honda owners, especially the older ones (cars not people, heh.) It worked so I'll see if I can get to the bottom of the speedo issues and post a how to.
I'm also great with rotary engines and the 2nd generation RX-7, I could easily hook one up to those. But I doubt there is any on here (mine sits in the garage lonely.)
Copyright ©2000 - 2020, vBulletin Solutions Inc.
