Old 07-30-2008, 05:08 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
how do i locate my speed sensor wire and injector wire?
hi
i don't think my vauxhall corsa has OBD2. i couldn't find it so i am planning on installing the mpguino. i have ordered a haynes manual for my car so hopefully that will shed some light.
is there an easy way to find the wires -can you trace them from the ECU or spedometer/injectors? is there a standardized colour scheme? can your multimeter help you?
there are loads of wires in a big bundle around the steering wheel, how do i know which ones?
im pretty confident i can put together the mpguino but its the vehicle interface bit which worries me!
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 07-30-2008, 05:12 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
If you can find a manual for the car, locate the ECU. From there, use pinouts for the ECU (should be in the manual, tells you what each pin/wire goes to) to figure out which wires you need, then just tap those.
Old 07-31-2008, 01:13 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
(Moved thread into the MPGuino subforum...)
Old 01-12-2009, 05:45 PM   #4 (permalink)
i've found a plug with two wires coming out of the gearbox is this the speed sensor?
i think i know where my injector plug is but the wires are really well compacted and heat shielded. it gonna be a job and a half to get at them.
Old 01-12-2009, 07:21 PM   #5 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Thought you found your OBDII port (AKA DLC = Diagnostic Link Connector) over in this thread???
Old 01-13-2009, 06:08 AM   #6 (permalink)
it wasn't obd2 compatable & scan gauge didn't work
