Mpguino software for older cars with carb
I am new here and have built the Mpguino very nice circuit, but I have an older car with a carb has anyone moded the software to run on a flow sensor pulses and maybe ignition pickup circuit for rpm I have orderd a flow sensor on ebay that they use for the new coffe machines
http://img268.imageshack.us/img268/2463/597604178o.jpg I need to test if the plastic withstands petrol but at only $8 to buy can't go wrong they come in 3mm and 2mm bore sizes and would do the job well as they measure the amount of liquid to fill a cup I think this would make the unit universal and could be used on any car |
know what kind of signal it will output? i see it indicating a square wave, which may work, you'll just have to mess with the uSec/mSec per gallon calculation a lot to get it to match up.
I will try that but from what i understand about the software it calculates MPG by the injector pulse width wouldn't it need to be changed to pulse rate?
You can find some information here: http://ecomodder.com/forum/showthrea...sel-16711.html The issue is the same for carb and old diesel engines.
Hello dom444
Do you have some more detailed information about that flow sensor? I have also searched for flow sensors suitable for fuel flow measuring. |
Not much to tell I don't have mine yet just ordered it, I have 2 coming but they are only about the $8 dollar price on ebay from china they are designed for the coffee machines.
type in ebay "coffee flow" in a world wide search they operate on 5-24v and have a pulse output they don't supply anymore information than that, when I get them will be able to tell you more. I also need to make sure they can withstand petrol. |
here is some info I found on one of them:
For the sense of the water flow rate on the following equipments: Thermostatic water heater, water purifier, water dispenser, smart card equipment, coffee machine etc. frequency =26*Q(Q: L/min) , Inner diameter :3.0mm,Flow rang:0.5-5L/min Maximum current:15mA further searching says they are made from Polyoxymethylene or POM material which according to Wikipedia is also used for fuel senders. |
Do you have fuel system with return line or without? With return line system two sensors are needed -- one for forward flow, one for back flow. Hopefully then we can program mpguino to measure the difference between flows, and calibrate it. It shouldn't be very difficult. |
Mine is standard four cylinder petrol car fills the carb then stops should be easy as long as there is enough flow but i think the flow meters are a paddle wheel design with a hall sensor so should still turn even on low flow rates i would think.
just received the first sensor have a pic of it disassembled very simple design and has 2 extra holes in the turbine blade for additional magnets if required to increase the pulse count per liter or gallon.
http://www.freeimagehosting.net/et5rc here is a small video of the sensor working pulses showing on an LED http://youtu.be/sINe8f7ullc |
I have a 94 gmc td diesel with OBD1, it uses a PMD, pump mounted driver that runs the ip pump, I'm thinking the pulses are of the duration type, and should run the MPGunio like vss on an injector. Any thoughts or experience with this system anyone?
I think first of all you should use oscilloscope and check all the signals from ECU to Injection pump. If you'll find signal that is varying in time proportionally to the supposed fuel dose you may try to use it for MPGuino. After some calibration you should check if the numbers are corresponding to the pump. If yes, there you go!
