EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   MPGuino Values lost after powered down? (https://ecomodder.com/forum/showthread.php/mpguino-values-lost-after-powered-down-19284.html)
JJMunoz 10-26-2011 01:03 AM
Hey guys.
I hooked up the MPGuino in my 94 Civic DX today and I noticed something about it which is problematic.
I incorporated a power switch in the circuit so that the MPGuino doesn't have to be on when the car is off and parked.
However, when I turn the power off I lose my Tank miles and distance.
My U/Sec and VSS Pulse figures remain saved though.
Any way to fix this?
Or does everyone else leave their MPGuinos powered on all the time?
Thanks.
JJ
dcb 10-26-2011 01:17 AM
mine is on, always, about 20milliamps idle. The backlight turns off after 7 minutes of no activity. It keeps the setup parameters in eprom, but the trips are in ram for speed/accuracy.
JJMunoz 10-26-2011 01:48 AM
Awesome! Thank you!
meelis11 10-26-2011 03:29 AM
In wiki section there is code how to save tank parameters to eeprom - so you dont lose them if you want to disconnect mpguino sometimes or you get power loss.
I made some changes to my code so mpguino goes to sleep and consumes around 5-6 milliAmps. If someone is interested, I can check code and put that part here or in the wiki. It was quite easy actually, just added one line into that block where backlight is turned off.
