EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   MPGunio on Flow Sensor?? (https://ecomodder.com/forum/showthread.php/mpgunio-flow-sensor-22792.html)
racprops 08-01-2012 10:53 AM
Sorry if this has been done or covered in another thread.
I have figured out a way to put a fuel flow sensor in my Ford.
With so many of my mods going to effect the injector duty cycle in-spite of the PCM, I am going to install an old Emco MPG Computer, unless I can be show a way to run the MPGunio off a pulse from a fuel flow sensor.
I would really like to keep the MPGunio as my main MPG readout.
Rich
touring21 08-01-2012 11:01 AM
if you do a search on the forums Rich for mpguino and carby you will see a fair few posts
Good luck
racprops 08-01-2012 11:59 AM
carby
Thanks but does anyone solve the problem?
IF so can you provide a link.
Rich
touring21 08-01-2012 04:53 PM
Sorry I only read a couple of posts
The member that I brought my mpguino from Meelis could possibly change the code for you to count pulses instead of measuring the on time of the injector versus the off time
I dont know for sure but I would suggest you ask him
racprops 08-01-2012 06:04 PM
Thanks I will try him.
Rich
PS he seems to be no more...
