Muffler underbody clean up
So i noticed the under body is a mess Aerodynamics wise
well in the back end it has the 2nd muffler so under it is pretty "dirty" is there anyway ti fix this it all ready has a factory 6" air dam :eek: that i will be replacing soon due to "minor damage" (i just want it to look pretty :) ) |
resonator drag
Where there is the will, there is a way.
http://st.motortrend.com/uploads/sit...aust-pipes.jpg http://st.motortrend.com/uploads/sit...aust-pipes.jpg The bellypan and airdam sorta fix the same problem. Are you going to shorten the airdam? The bellypan is more effective. Lengthen the airdam and the bellypan is less effective. It's probably an non-linear relationship and too case specific for a general rule. |
