EcoModder.com
-   -   My best city test yet for my Wagon (https://ecomodder.com/forum/showthread.php/my-best-city-test-yet-my-wagon-16301.html)
Smokingwheels 03-02-2011 07:55 AM
* 1984 4 cylinder 2L Wagon with carby and special porting*
* ambient temperature, 29.9 Deg C
* humidity, 13%
* Windspeed/direction, ENE/16km/h
* fuel grade/quality, ULP
* payload, Full tank + 85 Kg + notebook pc witch is my engine timing controller
* elevation, about 306 m AMSL
* road grade, fairly flat
* speed, 40-50,60, 60, 60 Km/h eg running laps around the block 12 times with stop signs on each corner.
* other traffic lots on one side of the run around the block 12 Times eg crosswalk
* driving style, no hooning here, About 200mm of Hg when accelerating
* Compression ratio, approx 10.5
* Distance on run 67.604 km
* idle time about 15%
** Fuel Consumption **
Best test results 6.271 L/100, 37.51 mpg (us), 45.05 mpg (imp)
normal running 11.2 L/100, 21 mpg (us), 25.22 mpg (imp)
My Tacho Graph
http://i231.photobucket.com/albums/e...2010/City3.jpg
And for some more stats see http://203.161.71.130/forum/topic.asp?TOPIC_ID=9
