EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   My Citroën C3 1.4 HDi DV4TD (Common Rail Turbo Diesel) thread (https://ecomodder.com/forum/showthread.php/my-citroen-c3-1-4-hdi-dv4td-common-32518.html)
sael 08-07-2015 11:01 AM
Hi guys.
After reading a lot of time Ecomodder, finally i start with my ecomodds.
The first thing that i did was adjusting the nut behind the wheel and all i can say is WOOOOOOW. I never think that i can obtain a -20% fuel consumption only from that :eek:
So after buying a bluetooth OBD and installing torque app was ready for the modds!
This is the screen that im running at the moment on torque:
https://dl.dropboxusercontent.com/u/...isc/torque.png
After some time of learning my car beaheavour I was ready.
1) Tire pressure to 42 PSI. Not the max but what i feel comfortable.
2) Down grill block 75%. From behind with a plywood painted black
3) Upper grill block 100%. Ghetto version on the cheap :D. I failed in the pr0 version make. -> This gives me -5% engine LOAD at 90 km/h. Cant believe it!
Cheers!
Sorry my english :D
Some pics from the car and mods.
The first mod:
The down grill block. So perfect that you must be magician to see it! :D
https://dl.dropboxusercontent.com/u/...s%202013/4.JPG
Second mod: Upper grill block
The pr0 version that failed by cracks on the bondo! Now on the trash.
https://dl.dropboxusercontent.com/u/.../formando3.jpg
https://dl.dropboxusercontent.com/u/.../formando4.jpg
https://dl.dropboxusercontent.com/u/.../formando5.jpg
https://dl.dropboxusercontent.com/u/.../formando6.jpg
https://dl.dropboxusercontent.com/u/.../formando7.jpg
https://dl.dropboxusercontent.com/u/.../formando8.jpg
https://dl.dropboxusercontent.com/u/.../formando9.jpg
https://dl.dropboxusercontent.com/u/...formando10.jpg
https://dl.dropboxusercontent.com/u/...formando11.jpg
https://dl.dropboxusercontent.com/u/...formando12.jpg
https://dl.dropboxusercontent.com/u/...formando13.jpg
https://dl.dropboxusercontent.com/u/...formando14.jpg
https://dl.dropboxusercontent.com/u/...formando15.jpg
https://dl.dropboxusercontent.com/u/...formando16.jpg
https://dl.dropboxusercontent.com/u/...formando17.jpg
https://dl.dropboxusercontent.com/u/...formando18.jpg
https://dl.dropboxusercontent.com/u/...formando19.jpg
https://dl.dropboxusercontent.com/u/...formando20.jpg
https://dl.dropboxusercontent.com/u/...formando21.jpg
Finally the upper grill block in ghetto version:
https://dl.dropboxusercontent.com/u/...C3/ghetto1.png
https://dl.dropboxusercontent.com/u/...C3/ghetto2.png
BabyDiesel 08-07-2015 04:08 PM
Looks OEM sael! You're doing fantastic so far :thumbup:
