EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   My Kamm back (https://ecomodder.com/forum/showthread.php/my-kamm-back-29321.html)
counterbond 06-23-2014 06:50 PM
My Kamm back
Whathttp://i10.photobucket.com/albums/a1...psliyvghii.jpg do you guys think about it.. Should it be higher?
mikeyjd 06-23-2014 07:15 PM
hard to say
We would need a side shot of the car to compare it with the template.
Here is a link to the template Aerodynamic Streamlining Template
Gealii 06-23-2014 07:18 PM
i request a more side pic of the whole car as it sits now. Not an angled pic like this one. I want this so i can put the aero template to it and see how good it is. either way it should be an improvement.
or it can be done yourself
Aero Template Overlay ver.0.6-alpha
just align the "0" to the tallest part of your car
spacemanspif 06-23-2014 07:18 PM
Not sure how long the tape will hold up but I'm very interested to see your results. Did you rivet the sides right to the body?
How did you get the plexiglass skirts to flex out at the front to clear the lower half of the wheel/tire?
aerohead 06-24-2014 03:38 PM
edge radii
Your headed in the right direction,and as soon as we get an image we 'll be able to tell about the downslope.
One thing I want to mention is that these rooflines need some softened edges where the roof and sides come together.With a hard intersection they're prone to create longitudinal vortices which have remarkably high drag.
Here's an image of Kamm's personal car and one of his wind tunnel models with the hard edges.You can see the tufts 'flying' into the vortices,the whole length of the car.http://i1271.photobucket.com/albums/...3-29BampW1.jpg
http://i1271.photobucket.com/albums/...3-29BampW2.jpg
Fat Charlie 06-25-2014 08:10 AM
A fitst step, however ugly, is better than not taking the step. Like 99% of us. Great job, I can't wait to see how it gets over time!
freebeard 06-25-2014 12:29 PM
What do you guys think about it.. Should it be higher?
Do you plan on changing it? Absent the requested side view, I'd say "Not higher—longer." It appears to be sway-backed, The center could be a few inches higher making a convex curve. Lay a flexible strip on the roof and let it sag to the 12° angle and follow that.
Notice the way Redneck handled the rear wheelwells on his Geo XL1, smoothing over the wheel arch and bumper.
http://i536.photobucket.com/albums/f...psb3390867.jpg
How stiff is the clear material you used (I assume that rectangle on top is clear as well)? If it vibrates, that is unhelpful.
counterbond 06-25-2014 07:14 PM
http://i10.photobucket.com/albums/a1...ps13mqp4mn.jpg
aerohead 06-26-2014 03:31 PM
Kamm back
Originally Posted by counterbond (Post 432004)
counterbond,you're on the right track.Here is a drag table from Hucho's optimization study of the 1st-gen Golf/Rabbit.The Golf happens to hit a drag minimum up near the 'Template'.VW was not allowed to build like this,as it violated Giugiaro's 'styling',although,you can see that we had to wait quite a while to see a VW with drag as low as the 1974 results.
http://i1271.photobucket.com/albums/...an01-18-14.jpg
freebeard 06-26-2014 09:13 PM
http://ecomodder.com/forum/member-fr...5-100-0618.jpg
Here's what I meant by "lay a flexible strip on the roof". I used 16' long wood strips because I was interested in the windshield area as well.
