View Poll Results: Small motor EV build w/ Trans...yes or no??
Yes, a small trans with a small motor would work well 1 16.67%
No, electric motors don't need transmissions. 5 83.33%
Why the hell are you making an electric scooter project? 0 0%
Voters: 6. You may not vote on this poll
Old 05-11-2009, 08:42 PM   #1 (permalink)
Need some further input on EV build
Ok, I know I sound like a broken record but I was wondering if you EV guys could help me better understand my build process.
These items I'm showing you are all hypotheticals but I'd like to see what you thought about them if they were all fabricated to work together.
The first pic is a brand new 48v golf cart motor and the second is a close ratio 6spd Harley transmission. Both items combined would be under $1k. If I were able to mate them up and throw on some good batteries wouldn't I have a pretty decent little scooter?
the reason I ask is that the motor is rated for about 13mph at 3000rpms. I figured with the trans I'd be able to string that out a lot longer while still having punchy acceleration. Am I right?
ID:	3453   Click image for larger version
Name:	harley trans.JPG
Old 05-11-2009, 09:39 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Sorry, me again. I was wondering about this too.
transmissions don't come free. that harley trans costs you 5 hp per here:
Six speed, HD or Baker?
The ebay auction for that motor lists it at 9.8 hp, and that may be a peak figure.
So it doesn't look like a good match.
Old 05-11-2009, 10:13 PM   #3 (permalink)
order99's Avatar
What top speed do you want for this scooter, and is 9.8HP a continuous or peak number? Most 48V Golf Cart motors i've seen rate between 4.5 to 5HP continuous.
I honestly don't see a problem with a fixed-gear for a scooter. Transferring that motor from a Cart chassis to a Scooter eliminates a massive amount of weight-with a Scooter you will likely have speed and torque to spare. Just play with the gear ratios until you get it right balance between smooth cruising and hill climbing.
As an example-I ran a WV 12V, 30A generator and a (borrowed)19.5V, 3.3Ahr Dewalt pack on my bicycle at a 4:1 gearing a few weeks back-I buried the needle(antique speedo only goes to 30MPH!) sprinted up a 10 degree slope and left the ground briefly at the top... When I save enough for a real 24V NiMH pack at 24V, i'll have to go 6:1 at least!
Now, that VW generator has 1HP or less at 20V...see why I think you'll have power to spare on the scoot?
Have fun!
Old 05-12-2009, 12:32 AM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
My electric car has a very similar motor to that, 48V, 6hp, 3000rpm and at 1,400 pounds + two passengers is rated to go 40mph, with out any transmission.
Old 05-12-2009, 02:22 AM   #5 (permalink)
So let me see if I follow.
You're saying the motor is capable of much higher speeds but the weight is keeping it to just 13mph even though it's "geared" for 40mph??
A 40mph top speed is unacceptable but perhaps using a 2 speed trans would provide me the grunt I'd want off the line with a top speed more around 60mph.
Old 05-12-2009, 05:29 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
generally speaking, for a given amount of power:
more weight=less acceleration
more drag (larger blockier shape that has to move more air)=less top speed
There will be a quiz
Old 05-12-2009, 02:24 PM   #7 (permalink)
no no, I understand that. What I'm trying to find out is if the 48v motor provides enough power to run at much higher speeds but it's being held back by the weight of the cart.
If that's the case then NO a trans wouldn't be needed (necessarily). It just seems to me that any motor that can only go 13mph and spin 3000rpms will need a trans to achieve 60mph (if at all possible). But what you guys are saying is that I just need to cut the weight down and make it more aerodynamic to achieve better speeds.
p.s. This is a 48v motor...I hear people saying they'll run 72v through them but not much more than that...is that safe? How can you tell how much power a motor will hold? I thought they were rated clearly for a reason.
Old 05-12-2009, 03:16 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
I don't have exact figures, but I recon that if ryland can go 40 with that motor, that IF you can cut your cdA (Coefficient of drag * frontal area) to half that of the citicar then you can do about 60 (assuming batteries and controller are up to it) using just sprockets (no trans maybe), but you have to use an overall ratio that is %50 greater than rylands.
If you also cut the overall weight in half for that same amount of power, your acceleration (i.e. 0 to 60) will double (how is that LiFE GB coming?).
Though it might be fun to try the two motors parallel serial shifting controller trick like the killacycle and white zombie do. So maybe design it so you can add a second motor or two wheel drive later?
Last edited by dcb; 05-13-2009 at 03:10 PM.. Reason: removed tesla reference, not serial
Old 05-12-2009, 03:59 PM   #9 (permalink)
In my mind, an electric motor and a small gearbox is a good idea. It gives you the torque and efficiency of the electric whilst retaining a decent top speed and range.
Not to mention that with a gearbox you can select the gear which keeps your motor happiest, at almost any speed.
Though, id have thought a 3 or 4 speed would be enough..
Are you having a clutch too, or direct to gearbox?
Old 05-12-2009, 04:08 PM   #10 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Don't get hung up on speed/rpm figures. That speed/rpm is for a particular vehicle and gearing. Focus more on V, I, P figures. You've got 10hp to play with - how fast does a 10hp gasoline scooter go?
Would appreciate input on EV purchase opportunity NachtRitter Fossil Fuel Free 4 05-09-2009 03:25 AM
EV from Scratch Build Thread - Please feel free to contribute! Blue Bomber Man Fossil Fuel Free 29 04-15-2009 11:50 AM
Newbie to the field, how hard to build an EV bigdude101 Fossil Fuel Free 4 04-14-2009 12:24 AM
Why don't you walk, ride a bike, or build a cheap EV? Daox General Efficiency Discussion 35 12-28-2008 09:41 PM
Looking to build a EV Drone Introductions 4 06-04-2008 11:35 AM
