Old 05-15-2008, 02:06 AM   #1 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
Why won't my engine start on neutral at 50+ MPH?
One time I tried turning off my engine on the freeway to coast down a very long slight decline and I couldn't get my engine to start up again at high speed, ended up having to pull to the emergency shoulder (complete stop) to start up again on drive.
Why?
Old 05-15-2008, 07:17 AM   #2 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
I've never had that kind of problem. What kind of car do you have?
If you put your car in park by mistake, or if you moved the lever even close to the park position, your car will still coast, but it will not restart.
Old 05-15-2008, 07:59 AM   #3 (permalink)
BBsGarage's Avatar
BBsRide - '06 Toyota Corolla CE
90 day: 31.64 mpg (US)
Does it start in neutral when you are not moving?
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 05-15-2008, 08:40 AM   #4 (permalink)
Fortuga - '03 Subaru Forester X
90 day: 21.68 mpg (US)
The Beater - '94 Nissan Sentra EX
90 day: 28.88 mpg (US)
If it's an Auto the answer will most likely be yes. Mine does.
Old 05-15-2008, 09:17 AM   #5 (permalink)
BBsGarage's Avatar
Never Assume.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 05-15-2008, 09:43 AM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I'm still surprised that people are trying this technique on the road, without learning their vehicles' specifics in advance.
BBsGarage pointed out the obvious: you need to know if your vehicle can be started in neutral. Some can't be.
Old 05-15-2008, 12:52 PM   #7 (permalink)
It sure as hell can! I do it all the time at stoplights! And its an automatic 05 Toyota corolla LE we're talkin about here...
Maybe it was a freak thing.... I guess I'll try it again sometime and see if I can't get it to start up again at high speed :/
Old 05-15-2008, 01:03 PM   #8 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
I had rented a Pickup for yardwork and had EOC's in N to a stop.
I could NOT start the truck in N - had to shift to park to start it.
was a Ford 250 P-up.
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 05-15-2008, 01:58 PM   #9 (permalink)
BBsGarage's Avatar
When you start in neutral at a light, is your foot on the brake?
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 05-16-2008, 12:34 AM   #10 (permalink)
Come to think of it,yes, yes it usually is...
I'll have to try doing it without pressing the break and see if it works or not, if not, that means I can't be shutting my engine down on the freeway :/
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
EOC (keep in neutral or 5th gear?) Pillzilla Hypermiling / EcoDriver's Ed 18 08-25-2009 08:58 PM
New York mechanic Andyman Introductions 6 05-13-2008 12:02 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
