EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   My scooter battery keeps cooking! (https://ecomodder.com/forum/showthread.php/my-scooter-battery-keeps-cooking-31772.html)
spazfishy 04-19-2015 11:25 AM
Guys, I have a problem and hoping an expert can help me. I have a CFmoto glory and it is cooking batteries. I have literally gone through 4 batteries now and each one of them are completely drained of acid also leaving a nice ruined paint job on the scooter too as the acid was leaving. I have tested to see if the battery is receiving a charge and it is but if I leave the battery connected over a week or two I will come back to a completely dead battery drained of all acid. This is with the scooter simply being stored, nothing running. Does anyone know what I need to replace or test to fix this. I am about to sell it as is cause I cannot continue to buy batteries.. Thank you
Hersbird 04-20-2015 03:34 PM
Are you sure it goes dry just sitting and not while it is running but you don't notice because you don't need the battery once it's running. If it is overcharging it will boil the battery, that would be a problem with the voltage regulator. Also the battery has a vent line that should just be open, if that got connected to a vacuum port it could suck the battery dry. If you see external leakage ruining the paint maybe there is something damaging the case.
Daox 04-20-2015 03:38 PM
In the short term, you can add water to battery cells. You don't add acid to them. The water evaporates and you'll need to add more eventually.
Other than that, I'd definitely check to see what kind of voltages you see while running because like Hersbird said it could be overcharging and boiling the water out. In that case, the regulator is in need of attention.
spazfishy 04-20-2015 03:50 PM
Thanks for the replies. Yes, I have gone through 3 or 4 batteries now and all have boiled out every last drop of acid so I don't think it would be anything battery specific. The last battery I purchased I never used to operate the scooter, I never went riding with it. I only maybe started it a few times and i kept on testing it with the vom. Eventually the battery was also dead so i really think something is draining or cooking the battery while it is not operational or being stored. I have no trickle chargers hooked up either, you just let it sit connected to the scooter and after about a month the battery has no more acid and the scooter has more ruined paint. Do you think this would be a short or the regulator? I did check the voltage to see if the regulator was charging the battery while it was running and everything checked out fine. I forget the specifics but it was supplying a normal amount of current to the battery according to my technician friend I had with me at the time. Does the regulator do anything when the bike is not running? To me signs point to the regulator but I dont know if it has any part when it's not running. If not then maybe a short somewhere and what would be the best way to troubleshoot that? Thanks again for both replies thus-far.
Hersbird 04-20-2015 04:42 PM
While it is sitting, even if there was a drain on the battery like say a short or the headlight left on, that shouldn't drain the acid in the battery. The battery would be 100% dead but full of fluid.
2000mc 04-20-2015 05:21 PM
Exactly what voltages do you find when measuring at the battery, at idle? At 2000-3000rpm?
spazfishy 04-20-2015 08:35 PM
The acid is draining or cooking till evaporation. I have gone through 3 batteries now, all cooked. Any idea what could cause it then?
spazfishy 04-20-2015 08:37 PM
I honestly forget but I remember it being normal and providing a proper charge to the battery. I am waiting a new battery from Amazon which i should receive Wed. I will test this again once received.
spazfishy 04-20-2015 08:38 PM
Could anything cook a battery while not running?
gone-ot 04-20-2015 09:15 PM
OVER charging the battery...either by (a) too much voltage, (b) too much current, or (c) charging too LONG. All of which are controlled by the battery charger used.
What KIND of charger are you using? There *IS* a difference.
• A "CHARGER" is designed to quickly "re-fill" a depleted battery by applying a voltage somewhat HIGHER than the battery's intrinsic voltage (ie: 14VDC into a 12.6V battery); it should NOT be left connected for long periods of time. Once the proper battery electrolyte acid-ratio has been achieved (indicating FULL charge) the charger should be immediately disconnected. Pumping 14V into an already fully-charged 12.6V battery will over HEAT the electrolyte causing it to "boil" and evaporate away as you describe.
• A "FLOAT" or "TRICKLE" charger is designed to slowly (trickle)& periodically (burp) "top-off" an already "full" battery during extended periods of non-use; it CAN be left connected for long periods of time.
spazfishy 04-21-2015 10:23 AM
• A "CHARGER" is designed to quickly "re-fill" a depleted battery by applying a voltage somewhat HIGHER than the battery's intrinsic voltage (ie: 14VDC into a 12.6V battery); it should NOT be left connected for long periods of time. Once the proper battery electrolyte acid-ratio has been achieved (indicating FULL charge) the charger should be immediately disconnected. Pumping 14V into an already fully-charged 12.6V battery will over HEAT the electrolyte causing the it to "boil" and evaporate away as you describe.
Hmm, well I do not recall the brand names but I to figured this might be the problem at one point, I no longer do. I have used two trickle chargers now and larger battery charger set on trickle settings. I do not keep the charger connected past the red light going to green indicating a full charge. Problem with this is that the last battery purchased was factory activated with no initial charge needed. It was also sealed and leak proof. This battery was only used to test the machine to try and figure out why my batteries keep on dying. The plan was to unhook a bunch of items and check the battery daily with a vom to see if it still reads above 12 volts. I checked it daily then weekly slowly hooking things back up to it. Well the battery never dropped below 12v. Months later I tried starting the machine and although all the lights turned on the battery could not turn it over. It was reading 12.1 volts so this was the first time I hooked it up to a charger. I trickle charged it slowly up to 12.7 and again tried to start it. Same thing, lights came on but not enough to start the engine. I then tried the battery in another scooter and same thing no juice. So yeah, I have not opened it but although the battery does now read 12.7v it no longer works. I am assuming it is also drained of acid now. Now I did test it a few times so at one point it did work. Basically it sat in my garage only used a few times to test the machine, I did not even ride it. Now, its completely dead just like the 2 other batteries before it. I do not know what to test next. If it helps the scooter is efi and water cooled. Thanks.
gil 04-21-2015 05:20 PM
Any corrosion on the battery terminals? Corrosion would limit the amount of current reaching the starter.
Gil
Hersbird 04-21-2015 06:45 PM
I have seen batteries show good voltage but they didn't have the cranking power to start a motor. You shouldn't let a battery completely drain. And you shouldn't constantly charge it either. Those good battery tenders Old Mechanic mentioned do a good job but otherwise you should disconnect the battery if you are going to leave it for months especially if you have some current draw somewhere. I bet its a combination of overcharging while running or on a charger and sitting a long time with a draw.
spazfishy 04-21-2015 07:11 PM
Yea, I certainly don't want a battery to completely drain and trying to figure out why it is doing so. I will certainly be disconnecting the battery now after every use/test until I figure out what is causing the drain. I have used battery tenders on battery 1 and 2. At one point I thought the tenders/chargers were at fault but the last battery never touched a charger and I was hoping I could find the cause of the drain with drops in voltage but unfortunately there were no drops in voltage so I kinda thought maybe my problem was over. But then I tried to start the scoot only to find out this battery is shot too. Now, to find that drain. Hmm.. How do we do that? Tomorrow I hope to get my new battery from Amazon and I will post volts at idle and with rpms. However, I think drain is happening when not running as my last battery ran no longer that 10 minutes and it eventually died as well. I will also perhaps try to replace the regulator as I have no idea where else to start, besides some tips here which I will reread and attempt to test any of the replies that have suggestions.
Here is a question. Lets say at one point in time I had a tender or charger connected to the battery while connected to the bike and maybe it was more charge than trickle or maybe the leads were incorrect. Could this possibly break anything on the bike causing it to fry every battery connected moving forward? If so which piece would it damage and maybe I should replace?
Thanks guys
3dplane 04-21-2015 08:58 PM
First you need a GOOD meter. I'm sure there are some inexpensive decent ones out there but I personally only trust my fluke meter when it comes to serious diagnosis and I need to see down to an accurate reading of only a few milliamps.
Then you need a good battery because a drain is obviously not going to show up with a dead battery.
Then you need to know how to hook up a meter for parasitic drain test.
The meter will be on the DC Amp (or DC milli Amps) setting with the leads inserted in the appropriate holes on the meter.
The other end of the leads go INLINE with the battery cables.
Meaning the battery will be connected to the scooter as normal then you disconnect ONE of the battery cables from the battery and one of the meter leads will be connected to the battery post and the other lead to the disconnected battery cable!
Ensure that everything is turned off on the scooter,take the key out.
Before you make the final connection of the second lead to the battery cable please do this: Touch and hold the battery cable to the battery post like you are reconnecting the battery to the scooter-
While touching the cable to the batt.post,connect the meter lead to the battery cable and now remove the batt.cable away from the batt.post!
This may save the fuse in the meter from the initial surge of amps upon connection that may occur if there are any modules or capacitors on the scooter that could cause a rush of Amps through the meter!
So now you have the meter hooked up inline with the circuit and you can read milliamps of drain if there is any.
How many milliamps are acceptable drain on a scooter? Beats me but if I had to guess based on the size of the battery than I would say no more than maby 2-3 milliamps. ( on a car with a 55-60 A/h battery max 25-35 mA drain is acceptable but tipically on a good car you will see 7-13 mA drain depending on how many modules and memory demanding crap it is equipped with like onstar,remote keyless entry etc.)
When you estabilished that it has an excessive drain lets say 1200 mA (1.2 Amps) then you start pulling fuses one by one or disconnecting components to narrow down the circuit with the drain on it.
This requires some mechanic with experience doing this so get help if you need to!
Don't fry the meter by accidentally turning on a load that exceeds the meter's capacity (or it's fuse's rating)
Oh and a battery voltage reading will only show you state of charge of the battery and has nothing to do with wether the battery is any good or not!
(you could put ten tiny watch batteries in series and you will read 15 volts but will it crank a starter motor? Heck no!)
You need to load the battery to see if it can hold decent voltage during a nice load like say all the lights turned on or cranking the scooter.
For example you could set up the meter to read voltage (don't leave the leads in the AMPs hole in the meter),hook it up to the battery to read voltage ,then attempt to crank the scooter while reading voltage.
If the volts drop to near zero then you got a bad battery,if the voltage does not change then you got a starting circuit problem. Just some examples.
spazfishy 04-22-2015 12:37 PM
Thanks for such detail! I will be printing this and hope to start tests soon. Maybe tonight, I did just receive a new battery. I might need to pick up a more sophisticated meter however.
Anyways, I will certainly post back any findings. Thanks a lot to you all, I know any reply takes your much valued time!
spazfishy 04-22-2015 08:09 PM
The new battery is measured at 12.76 volts, at idle it is 13.85 volts, at rpm it is 12.76 volts.
spazfishy 04-22-2015 08:22 PM
[QUOTE=Then you need to know how to hook up a meter for parasitic drain test.
[/QUOTE]
Now I will prove exactly how inexperienced I am and hopefully you can still help me. I posted the volts for the new battery in a previous email. I am now failing at the how to hook up and read a meter for the parasitic drain test. I will insert a picture of the VOM I am using. I do know it is about the cheapest vom money can buy and if it is not going to do the job I can get my hands on a better one soon. Like, I mentioned though I am very very inexperienced with this so I am not sure which setting you are telling me to set it to. Please let me know what to set it to on my vom when you see the picture to complete your parasitic test. Next, I am confused a little about the battery hook up piece. You say to disconnect one lead from the battery, can it be positive or negative? Does this matter? Next the battery post, is this simply the cable that is still connected to the battery, is that the post? So if I am getting this part correct I would disconnect one cable from the battery, could be positive or negative. Then connect one wire from the vom to the loose cable and one wire of the vom to the connected wire. I am guessing the positive and negative on the vom do not matter at this point too. Is this correct so far? Please let me know which is the correct setting on my vom and if my logic is correct. I will then report back the milliamps of drain. Thanks again for your time. P.S. my father is pretty decent at this stuff so he can help me if it gets more complicated but I am flying solo for now. Also, if you have a computer problem I might be able to help. :P
http://bit.ly/1Je1NK1
3dplane 04-23-2015 11:52 AM
You are right I did not mention that it does not matter which post you disconnect and it does not matter what lead you put where!
All it is going to do is display the current flow as negative if it is backwards. It will be the same amount as forward.
As far as hookup,you are making a connection between your disconnected battery post and the disconnected battery cable with your meter leads.
One lead touches the 'naked' batt post,the other lead touches the disconnected battery cable.
You are inserting the meter inline essentially reconnecting the battery through the the meter!
Your meter: move the red lead over to the hole that says 10 A.
Set the dial to the 10 A setting to start with.
If the lowest reading that it can display here is 0.1 A, that would be 100 mA (milli Amps) and if that is what you read,(too much draw) then you need to switch to read down to milli amps.
I don't know your meter but it looks like you would put the red lead back to the whole where it is on your picture and change the dial to be in the milli amps range say 200m setting in the DCA section surrounded by a green line.
On my fluke it auto ranges so it can display from 1mA to 10 A without having to touch anything.
BTW it seems your scooter only charging at idle! Not good!
Is the headlight on when it is running?
Hersbird 04-23-2015 12:37 PM
Somebody added an amp meter to my bike which I love. It simply shows if the battery is charging or discharging, and how much, or simply neutral.
You have to wire all the voltage through the meter, but they are inexpensive. Dodge used to put them on all cars and trucks up to the mid 70s. They were problematic there because all the electrical load had to run up under the dash and cars started getting to many electrical gizmos for the wiring and connectors to handle. A motorcycle is no problem though.
2000mc 04-24-2015 01:57 AM
That's not normal. The voltage at idle is higher than I would expect, but wouldn't indicate a problem on its own to me. Normally voltage revved up a bit will be greater than voltage at idle, but it looks like you're charging system quits on you. If it were mine I would have it get out a manual to further test the generator/ stator/ rectifier/ regulator... whatever it's got in its charging system
spazfishy 04-24-2015 09:20 AM
Great reply, thanks. I think I know exactly what to do now. I will check the headlight and report more back after further testing this weekend.
jjackstone 04-25-2015 06:06 PM
Don't overlook a possible bad starter. That's where you might see a battery drain when the engine is off. I've repaired three different cars in which the starter was going bad and would create a parasitic load on the battery. Didn't have the boiling away problem, but eventually the battery would become weak enough from to many low discharges that the car would no longer start.
JJ
spazfishy 04-26-2015 12:21 PM
Wanted to tell you the reading I am getting in the 10A position on my VOM is on connection 0.09 then reduces to a constant 0.01. I will test the 200m thing next but wanted to mention this. Is this high? Any clue?
spazfishy 04-26-2015 12:26 PM
Okay, in 200m position the reading is -05.5. Do you suggest then I disconnect everything in an attempt to find one that gets the -05.5 to go lower? Thank you
3dplane 04-26-2015 07:36 PM
My problem is that meter! What the heck is 05.5? Lol! I doubt it would display .5 milliamps but who knows.
The 200m range should mean that it would display milliamps from 0 to 200 so I would expect a round number there.
It's trying to display either 5.5 amps or 5.5mA.
What's it say in the 10A range? (with the red lead in the 10A connector)
Honestly I just don't trust that that thing but let's give it a chance!
spazfishy 04-28-2015 06:47 PM
Hey guys, have not done further testing in a few days. I will grab another meter and try to get more testing done tomorrow.
