Old 10-22-2009, 03:25 PM   #1 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
26% mileage improvement with TCC lockup switch
All I can say is WOW!
TCC lockup switch. Latest mixed tank fill netted 30.2mpg up from an average of 24. I can hardly believe it but there it is. Also got a record tank distance of 818km/508mi.
That's almost a 26% improvement. It may settle down a bit on the next tank but we will see. I doubt most people would get the same improvement because I live in a very hilly area where the slushbox was labouring up these hills at low speed, high RPM and I could never get into OD. Now I cruise the flats at 30-35 locked up in OD and do most of those hills locked up in 3rd or OD.
30mpg combined! So happy!
Thread is here: http://ecomodder.com/forum/showthrea...tch-10028.html
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 10-22-2009, 03:37 PM   #2 (permalink)
Wow, that is a ton of energy wasted through the torque converter.
Old 10-22-2009, 04:16 PM   #3 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Yeah, It's kind of hard to believe but way to large an increase to be an anomaly. My Bowen driving techniques are otherwise unchanged. I have been doing more EOC in town but that can't account for all of that increase. The needle does drop a lot slower in Bowen driving now, that's for sure.
Old 10-22-2009, 04:22 PM   #4 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
smart mod.
conquering an automatic hardly has options. Lucky for gadgetry yours obviously hacked nice.
A standard cannot be controlled by manufacturing,
the auto, it has been owned for gentle driving for a long time.
Old 10-22-2009, 10:34 PM   #5 (permalink)
Override switches ver opoular back in the80's with the Lockup torque converters
Eventually it faded away because it toasted the clutch in the lockup unit.
don't remember the specifics unfortunately but I do know your supposed to click the override button on a lot of new fords when towing so it does not use the OD or the Lockup.
Dave
Old 10-22-2009, 11:47 PM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Using the OD lockout on trucks while towing actually has nothing to do w/ the TCC... it's due to the fact that the transmission will constantly be shifting between OD and the next lowest gear, and that makes for added wear and heat, which will damage the transmission.
On most transmissions, TC lockup doesn't occur unless the selector is in the highest range, so if OD is deactivated, so is CLK.
I will re-re-reiterate once again that the ability to control the TCC will result in less wear because it won't engage/disengage every time you load the engine or when you let off the accelerator to slow down 1 or 2 seconds to give the guy ahead of you some cushion space.
Old 10-30-2009, 08:34 PM   #7 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Great Results! You have skillfully applied this mod!
Freezing the Slushbox. Torque Converter on-demand lockup switch. orange4boy EcoModding Central 269 06-13-2015 09:51 PM
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
